[Commercial meshers] Total Boundary Layer Height for an airplane
Old   April 10, 2019, 11:29
Default Total Boundary Layer Height for an airplane
MWRS
waseeqsiddiqui is on a distinguished road
Hello everyone. For a certain airplane containing multiple parts (Wing, Stabilizer etc.), how does one calculate the total boundary layer thickness?
Does one specify the total height differently for each individual component in ICEM or is it wise to specify one common thickness obtained using the mean aerodynamic chord of the wing for all individual parts?
waseeqsiddiqui is offline   Reply With Quote
Old   August 21, 2019, 10:09
MWRS
Anyone? Please help
Old   August 22, 2019, 03:03
Carlo_P
Carlo_P is on a distinguished road
Hey waseeqsiddiqui..long name!
I think that you are talking about the prismatic cells next to the wall, correct?
In that case, it is not always simple to know before the simulation.
You have to calculate the first cell high (h1) and then the total tickness is equal to
h1*(er -er*(N+1))/(1-er)
where er is the expansion ratio (normally 1.2) and N is the total number of cells.
h1 can be calculate with: https://www.cfd-online.com/Tools/yplus.php . h1 is the eximated wall distance.
After the simulation, you have to check if the yplus is between the correct range (1-10) for k-omega (20-200) for k-epsilon.
If yplus is inside this range in all the parts, you can maintein the same total tickness.
If yplus is too different in the different parts, you have to reduce the totaltickness where yplus is too high and increase if too low.
Sorry, but it is a complex answer!
Carlo_P is offline   Reply With Quote
Old   August 22, 2019, 10:01
MWRS
Okay, Thanks!
Validity & transformation of boundary layer equations Obad Main CFD Forum 2 April 27, 2015 02:59
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
