[snappyHexMesh] How to create layer that is normal to the surface of the geometry? |
April 27, 2019, 07:52 |
Joe lee
Rep Power: 7 |
I was trying to create a layer that is normal to the geometry edge/surface, which looks like this:
However, what I got is something like this: Can the layer mesh be refined to something like the first figure by adjusting parameters in snappyHexMeshDict? Thanks. |
April 27, 2019, 13:35 |
Rep Power: 11 |
I cannot see any layer mesh is created on the bike. Can you check or show how many percentage of surface is covering with layer mesh from the mesh log?
April 28, 2019, 02:45 |
#3 | |
Joe lee
Rep Power: 7 |
You are absolute right. I used to think those near surface mesh are the boundary layer. I checked the log, it seems the layer mesh could not generate successfully. Could you help me to take a look in it? I will attached the mesh log file, and the below is the snappyHexMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; snap true; addLayers true; geometry { figure { type triSurfaceMesh; file "figure.stl"; } refinementBox { type searchableBox; min ( 30 180 90); max ( 700 1760 1850); } }; castellatedMeshControls { maxLocalCells 100000; maxGlobalCells 10000000; minRefinementCells 10; maxLoadUnbalance 0.10; nCellsBetweenLevels 3; features ( { file "figure.eMesh"; level 6; } ); refinementSurfaces { figure { level (5 6); patchInfo { type wall; inGroups (figureGroup); } } } resolveFeatureAngle 30; refinementRegions { refinementBox { mode inside; levels ((1E15 4)); } } locationInMesh (402 1802 1002) ; allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 5; tolerance 2.0; nSolveIter 30; nRelaxIter 5; nFeatureSnapIter 10; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap false; } addLayersControls { relativeSizes true; layers { //"(lowerWall|figure).*" "figure.*" { nSurfaceLayers 5; } } expansionRatio 1.2; firstLayerThickness 0.001; minThickness 0.0005; nGrow 0; // Advanced settings featureAngle 60; slipFeatureAngle 30;. nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 15; } meshQualityControls { #include "meshQualityDict" } // Advanced // Write flags writeFlags ( scalarLevels layerSets layerFields // write volScalarField for layer coverage ); mergeTolerance 1e-6; // ************************************************************************* // Last edited by Jinjolee; April 28, 2019 at 10:04. Reason: This comment is no longer updated |
April 28, 2019, 03:19 |
#4 | |
Joe lee
Rep Power: 7 |
https://drive.google.com/open?id=13G...7ODyiq2taBjuOU |
April 28, 2019, 10:04 |
Joe lee
Rep Power: 7 |
Fun fact: I didnt know that when relativeSizes is on, the thickness would not be absolute value anymore. Now I changed firstLayerThickness to 0.3, and now there is 83% of layers generated. Is it possible to enhance the layer %? Since there are some places did not have layer generated properly. It is shown in the image below (notice the layers on the top-left region):
And there is my snappyHexMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; snap true; addLayers true; geometry { figure { type triSurfaceMesh; file "figure.stl"; } refinementBox { type searchableBox; min ( 30 180 90); max ( 700 1760 1850); } }; castellatedMeshControls { maxLocalCells 1000000; maxGlobalCells 100000000; minRefinementCells 15; maxLoadUnbalance 0.10; nCellsBetweenLevels 3; features ( { file "figure.eMesh"; level 4; } ); refinementSurfaces { figure { level (4 5); patchInfo { type wall; inGroups (figureGroup); } } } resolveFeatureAngle 20; refinementRegions { refinementBox { mode inside; levels ((1E15 4)); } } locationInMesh (402 1802 1002) ; allowFreeStandingZoneFaces true; } snapControls { nSmoothPatch 5; tolerance 1.5; nSolveIter 30; nRelaxIter 5; nFeatureSnapIter 10; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap false; } addLayersControls { layers { //"(lowerWall|figure).*" "figure.*" { nSurfaceLayers 3; } } expansionRatio 1.1; firstLayerThickness 0.3; minThickness 0.05; nGrow 0; featureAngle 180; slipFeatureAngle 60; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 130; nBufferCellsNoExtrude 0; nLayerIter 15; } meshQualityControls { #include "meshQualityDict" } // Advanced // Write flags writeFlags ( scalarLevels layerSets layerFields // write volScalarField for layer coverage ); mergeTolerance 1e-6; // ************************************************************************* // |
April 28, 2019, 11:34 |
#6 | |
Rep Power: 11 |
April 28, 2019, 11:54 |
Joe lee
Rep Power: 7 |
layer, normal to edge, snappyhexmesh |
[snappyHexMesh] snappyHexMesh generates not planar surface | krzychu111 | OpenFOAM Meshing & Mesh Conversion | 2 | April 23, 2020 16:38 |
[snappyHexMesh] Problem airfoil snappyhexmesh add layer | bye bye my blue | OpenFOAM Meshing & Mesh Conversion | 1 | May 5, 2017 05:56 |
[snappyHexMesh] SnappyHexMesh: Layer on corners | Pj. | OpenFOAM Meshing & Mesh Conversion | 9 | July 17, 2014 04:26 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
