About the Open Source Meshers discussed here
Like Tree6Likes
  • 3 Post By elvis
  • 3 Post By GerhardHolzinger
Old   March 1, 2015, 11:40
Default About the Open Source Meshers discussed here
Retired Super Moderator
Bruno Santos
The forum Open Source Meshers: Gmsh, Netgen, CGNS, ... was closed near the end of April 2019 and replaced with prefixes on the main OpenFOAM Meshing forum. The following is my original post that has been restructured a bit in function of the new forum structure. For more details about the new forum structure, read this thread: Map of this Meshing (sub-)Forum
It's expected that with this new forum structure, it is also used to discussing issues with generating and converting meshes that are generated with open source meshers that work independently from OpenFOAM. Nonetheless:
  • The objective is mostly to discuss how to generate and/or convert meshes that are usable by OpenFOAM, under the respective forum prefixes, when available.
  • As for using each open-source software, please refer to their respective official forums and mailing lists, as listed below.
Wiki page with more general information on how each open source mesher relates to OpenFOAM's meshes: HowTo Open Source Meshing
Reference links for each software:
Please provide more links below for other open source meshers that can be used to generate meshes for OpenFOAM, for complementing this post.
Last edited by wyldckat; April 27, 2019 at 09:38. Reason: Revised text due to the restructring of the forum
Old   March 15, 2015, 02:43
Elvis
elvis will become famous soon enough
Originally Posted by wyldckat View Post
elvis is offline   Reply With Quote
Old   June 4, 2019, 04:56
Default Salome now has an interactive CAD module
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
One flaw of the Salome software suite was geometry creation with the Geometry module, which was a tedious bottom-up, no-edits-possible sort of thing.
With the latest version of Salome, a new CAD module was introduced, which supports parametrisation and interactive editing of the geometry.
References
Announcement of Salome version 9.3.0
Shaper Video Tutorials on YouTube
snak, wyldckat and virengos like this.
GerhardHolzinger is offline   Reply With Quote
Old   June 5, 2019, 04:52
Enrico Segre
Enrico Segre is on a distinguished road
Originally Posted by elvis View Post
btw, forked for Salome 9.3.0 here, including salomeToOpenFOAM_GUI.py.
Enrico Segre is offline   Reply With Quote
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
Optimal OF compilation Tobi OpenFOAM Installation 16 September 25, 2013 13:39
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
