August 16, 2019, 07:01 |
Block with surface
I'm quite new in the meshing stuff, so snappyHexMesh is a bit confusing for me. I try to create a volume with a rough surface. With blockMesh I created a Mesh with the extension of 510x510x0.06. nx=ny=510, nz = 8. Now I try to create a rough surface by two STL files, top and bottom with a z-information at every point of the mesh. Each STL has a lateral extension of 512x512 (larger than the created mesh). The problem now is, that my lateral boundaries/borders look really bad with long elements in z-direction AND/OR totally missing elements. The surfaceCheck says, that my surfaces are fine. I attached the blockMeshDict and snappyHexMeshDict. The surface-files are to large for uploading. I think it's just the settings for snappyHexMesh, but I don't really know which parameters I have to adjust. So maybe somebody could have a quick look? Thanks in advance. Last edited by runer; August 16, 2019 at 08:52. Reason: Added a screenshot of a mesh with invalid boundaries. |
[snappyHexMesh] snappyHexMesh generates not planar surface | krzychu111 | OpenFOAM Meshing & Mesh Conversion | 2 | April 23, 2020 16:38 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
