[Commercial meshers] "can not find faces using edges.."when using the ICEM mesh
Old   March 17, 2020, 11:11
Post "can not find faces using edges.."when using the ICEM mesh
bany
bany is on a distinguished road
My mesh is built by ICEM with hanging nodes when using the refinement in ICEM. And when i convert it into OpenFOAM by fluent3dmeshtofoam with checkMesh being OK, the case can be calculated. But when i use the functionObjects which involves meshTool.C in controlDict, the error "can not find faces using edges.." comes.
More in detail, my domain is a cylinder. And i use the O-block to build the structured mesh in ICEM. To refine certain block, i use the refinement tool, which cause the hanging nodes and uncovered faces. But when i convert it into OpenFOAM using fluent3dmeshtofoam, the mesh is Ok as i check the mesh. So i think the fluent3dmeshtofoam can merge these hanging nodes, just like FLUENT which can deal with the 1=>2 ratio refinement. But when i run the case, i find the errors "can not find faces using edges..". Finally, i find the errors come from meshTool.C because i use the functionObjects which involves meshTool.C in controlDict.
You can find more detail in uncovered faces after refinement in 3D which is posted by me.
bany is offline   Reply With Quote
Old   March 31, 2020, 03:23
Default zipUpMesh
Maximilian Hansinger
mhansinger is on a distinguished road
I had the same error from the meshTools.C, also with a mesh generated with ICEM and hanging nodes. What you describe applies exactly to my setup, too.
I ran zipUpMesh and that fixed it for me.
mhansinger is offline   Reply With Quote
Old   March 31, 2020, 23:01
Default errors have gone
bany
I try to run zipUpMesh, it work well and the errors have gone.
And thank you very much!
Best wishes!
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
