June 17, 2020, 14:36 |
Tilted Channel in OpenFOAM
Rep Power: 6 |
Dear All,
I am trying to run a simulation of a titled plane channel at 45 degrees. I am wondering, what would be the easiest way to create titled geometry in openfoam? I tried to build a vertical channel using blockMesh and then use TransformPoints -rollPitchYaw (0 0 45), but it does not seem that this would rotate the coordinate axes too (probably causing problems for the velocity field). I would appreciate your assistance. Thanks |
June 18, 2020, 04:28 |
#2 | |
Carlos Rubio Abujas
Rep Power: 9 |
Maybe you should check the error message you're getting or how you defined the boundary condition and gravity on the case. Last edited by crubio.abujas; June 20, 2020 at 10:34. Reason: Adding profile |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
[snappyHexMesh] OpenFOAM mesh generation for irregular open channel | ksmithgall | OpenFOAM Meshing & Mesh Conversion | 2 | June 22, 2017 20:16 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
OpenFOAM open channel flow downsteam boundary condition | Brickman | OpenFOAM Running, Solving & CFD | 2 | November 5, 2012 20:14 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 13:50 |
