[snappyHexMesh] No surfaces found/specified for entry |
December 27, 2020, 14:13 |
owen
I'm a third year student trying to use snappyHexMesh on dsmcFoam. I've made an object in solidworks (just to get the simulation running) and saved it as an STL file, being careful to ensure its in ascii etc. Then I change all the relevant parts of the surfaceFeatureExtractDict to the name of the STL file. When I then run surfaceFeatureExtract the following error comes up. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _b45f8f6f58-20200629 OPENFOAM=2006 Arch : "LSB;label=32;scalar=64" Exec : surfaceFeatureExtract Date : Dec 27 2020 Time : 19:12:26 Host : DESKTOP-F47FKAM PID : 2298 I/O : uncollated Case : /home/owen/OPENFOAM4/flange nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Note: Feature line extraction only valid on closed manifold surfaces Reading surfaceFeatureExtractDict --> FOAM FATAL ERROR: No surfaces specified/found for entry: Part.stl From int main(int, char**) in file surfaceFeatureExtract.C at line 305. FOAM exiting ************************************************** ** However when I run the inbuilt blob file, it works fine. Do I need to convert to stl.gz for this to work? If so how could I do this on solidworks/another program. Any help would be greatly appreciated! Thanks |
[snappyHexMesh] SHM doesn't snap the boundary between two surfaces on same plane | decanter | OpenFOAM Meshing & Mesh Conversion | 4 | November 17, 2020 15:32 |
Combine part surfaces if along a specified plane | miragemobile | STAR-CCM+ | 1 | March 26, 2019 18:43 |
NURBS surfaces on a wing | frossi | CFX | 5 | February 5, 2017 15:27 |
[snappyHexMesh] SHM not snapping to some surfaces | Swift | OpenFOAM Meshing & Mesh Conversion | 13 | January 4, 2016 01:56 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
