[snappyHexMesh] nGrow Fatal Error 2JZ Supra!
Old   January 11, 2021, 14:01
Default nGrow Fatal Error 2JZ Supra!
noz
James
noz is on a distinguished road
Hi everyone!
I've been scouting for a while just using this forum as a go-to for help with CFD tutorials for a little while now.
I'm completing CFD in my MSc using OpenFoam and I've come up against a bit of a challenge.
For my project, I plan to complete analysis on two different car models and then compare them. Long story short, I own a modified mk4 Supra and thought it would be cool to compare the exterior changes I've made.
I struggled to properly mesh it, I believe there was just too fine a mesh for my computer to handle. So adjusted a few parameters and cable across a fatal error. Sad!
I had opened up paraView just to see if there was anything there, but sadly just an external box.
I copied the whole simulation from simplecar simulation which is knocking about online. I've noted the items I've changed.
I ran the simulation using a different model without issues. I've of course run through the step by step process using the new .stl file. Making sure I reselect the locationInMesh correctly etc.
Thanks!
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
simpleCarCfd
type triSurfaceMesh;
file "simpleCarCfd.stl";
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
// If local number of cells is >= maxLocalCells on any processor
// switches from from refinement followed by balancing
// (current method) to (weighted) balancing before refinement.
maxLocalCells 100000;
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
maxGlobalCells 5000000;
// The surface refinement loop might spend lots of iterations refining just a
// few cells. This setting will cause refinement to stop if <= minimumRefine
// are selected for refinement. Note: it will at least do one iteration
// (unless the number of cells to refine is 0)
minRefinementCells 10;
// Allow a certain level of imbalance during refining
// (since balancing is quite expensive)
// Expressed as fraction of perfect balance (= overall number of cells /
// nProcs). 0=balance always.
maxLoadUnbalance 0.20;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 1; // <------------------------------------- CHANGED FROM 3
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/triSurface for now.
features
file "simpleCarCfd.eMesh";
level 4; // <------------------ CHANGED FROM 6
// Surface based refinement
// Specifies two levels for every surface. The first is the minimum level,
// every cell intersecting a surface gets refined up to the minimum level.
// The second level is the maximum level. Cells that 'see' multiple
// intersections where the intersections make an
// angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
simpleCarCfd
// Surface-wise min and max refinement level
level (2 2); // <------------------------------------------- CHANGED FROM 3 4
// Optional specification of patch type (default is wall). No
// constraint types (cyclic, symmetry) etc. are allowed.
// Resolve sharp angles
resolveFeatureAngle 30;
// Region-wise refinement
// Specifies refinement level for cells in relation to a surface. One of
// three modes
// - distance. 'levels' specifies per distance to the surface the
// wanted refinement level. The distances need to be specified in
// descending order.
// - inside. 'levels' is only one entry and only the level is used. All
// cells inside the surface get refined up to the level. The surface
// needs to be closed for this to be possible.
// - outside. Same but cells outside.
refinementRegions
// Mesh selection
// After refinement patches get added for all refinementSurfaces and
// all cells intersecting the surfaces get put into these patches. The
// section reachable from the locationInMesh is kept.
// NOTE: This point should never be on a face, always inside a cell, even
// after refinement.
locationInMesh (839 267 10);
// Whether any faceZones (as specified in the refinementSurfaces)
// are only on the boundary of corresponding cellZones or also allow
// free-standing zone faces. Not used if there are no faceZones.
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 3;
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
tolerance 2.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 30;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 5;
// Feature snapping
//- Number of feature edge snapping iterations.
// Leave out altogether to disable.
nFeatureSnapIter 10;
//- Detect (geometric only) features by sampling the surface
// (default=false).
implicitFeatureSnap false;
//- Use castellatedMeshControls::features (default = true)
explicitFeatureSnap true;
//- Detect points on multiple surfaces (only for explicitFeatureSnap)
multiRegionFeatureSnap true;
// Settings for the layer addition.
addLayersControls
// Are the thickness parameters below relative to the undistorted
// size of the refined cell outside layer (true) or absolute sizes (false).
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
"(lowerWall|simpleCarCfd).*"
nSurfaceLayers 1;
// Expansion factor for layer mesh
expansionRatio 1.0;
// Wanted thickness of final added cell layer. If multiple layers
// is the thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
// See relativeSizes parameter.
finalLayerThickness 0.3;
// Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 1; <----------------- CHANGED FROM 0.1
// If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
// Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
nGrow 1; // CHANGED FROM 0
// Advanced settings
// When not to extrude surface. 0 is flat surface, 90 is when two faces
// are perpendicular
featureAngle 60;
// At non-patched sides allow mesh to slip if extrusion direction makes
// angle larger than slipFeatureAngle.
slipFeatureAngle 30;
// Maximum number of snapping relaxation iterations. Should stop
nRelaxIter 3;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 1;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 3;
// Smooth layer thickness over surface patches
nSmoothThickness 10;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 0.5;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 0.3;
// Angle used to pick up medial axis points
// Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
minMedianAxisAngle 90;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations. The mesher will exit
// if it reaches this number of iterations; possibly with an illegal
// mesh.
nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
#include "meshQualityDict"
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- Amount to scale back displacement at error points
errorReduction 0.75;
// Advanced
// Write flags
writeFlags
scalarLevels
layerSets
layerFields // write volScalarField for layer coverage
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
noz is offline   Reply With Quote
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
[snappyHexMesh] sHM: FATAL ERROR: More than six unsigned transforms detected Djub OpenFOAM Meshing & Mesh Conversion 0 July 15, 2014 04:43
[snappyHexMesh] keyword nGrow undefined in "...snappyHexMeshDict.addLayersControls" rama13 OpenFOAM Meshing & Mesh Conversion 2 April 16, 2013 10:06
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
