[blockMesh] Mesh conversion from Star CCM+ to OpenFOAM |
July 20, 2021, 08:08 |
murchana
Rep Power: 7 |
Hello. I would like to know how to convert a .sim file generated in star ccm+ (having a 3d mesh as well as boundary conditions set) into a OpenFOAM readable file. I am a complete beginer in OpemFOAM as well as Star ccm+.
Basically i would like to know how to convert a 3d mesh generated in star ccm+ to OpemFOAM. |
July 21, 2021, 08:45 |
Mark Olesen
Rep Power: 40 |
You need to export as a .ccm file (normally a .ccmg - for geometry) and then use a convertor such as ccmToFoam (in the www.openfoam.com version), for which you need access to the proprietary libccmio library.
Or you can possibly export your geometry as "proSTAR" format, in which case you can use the star4ToFoam utility. |
January 30, 2024, 07:06 |
mesh conversion is not working
#3 | |
ccmToFoam -help ccmToFoam: command not found how i want to fix this?, thanks so much. |
June 8, 2022, 03:45 |
Osman Veysel Özdemir
Rep Power: 3 |
I m new on OpenFOAM, I prepared a mesh in STAR CCM+ and I am trying to export it to OF. I searched about it and find this ccm26ToFoam. So now I am trying to use it but getting same error. Can anyone help me? Details: OpenFOAM-9 is installed on my ubuntu. My mesh is tetrahedral with prism layer from STAR CCM+. I can export it as .ccm format. ccm26ToFoam doesn't work. (There may be an issue about my installation but I did some analysis before without any problem by using rhoSimpleFoam.) |
June 8, 2022, 06:46 |
Mark Olesen
Rep Power: 40 |
Attempt to export as a proSTAR mesh (if possible) and use star4ToFoam. Alternatively, there are a variety of ccmToFoam, foamToCcm etc tools in the www.openfoam.com version (ie, from OpenCFD Ltd, not from OpenFOAM Foundation Ltd), but these will still require that you have access to the base-level libccmio library (proprietary).
June 8, 2022, 07:07 |
#6 | |
Rep Power: 3 |
I was using an OpenFOAM version from OpenFOAM Foundation, I will switch to ESI groups version. But I couldn't understand how can I install libccmio. |
November 22, 2023, 07:47 |
ccmtofoam
Tunc
Rep Power: 4 |
You can follow this thread:
[OpenFOAM-v1706] ccmToFoam error |
.sim, openfoam mesh, star ccm+ mesh |
[Salome] mesh conversion Salome --> OpenFoam | vaina74 | OpenFOAM Meshing & Mesh Conversion | 42 | March 4, 2022 20:41 |
[Commercial meshers] Mesh conversion .gtm to OpenFOAM | ansab | OpenFOAM Meshing & Mesh Conversion | 2 | December 6, 2016 13:48 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[Commercial meshers] Problems with ANSYS mesh conversion | tdog | OpenFOAM Meshing & Mesh Conversion | 1 | March 31, 2016 17:36 |
