[mesh manipulation] mergeMeshes destroys final mesh |
July 21, 2021, 13:50 |
Maciej Marczak
Rep Power: 5 |
Hi all!
I have an issue with using mergeMeshes utility. I am working on quite simple geometry (rectangular domain done by cfMesh and rotating zone done in Salome). Photos: https://ibb.co/vwqgRNy https://ibb.co/w78fPnn Both meshes pass checkMesh without any errors, but when I merge them using mergeMesh utility something goes wrong and checkMesh returns such errors: Code:
Checking geometry... Overall domain bounding box (-400 -600 0) (1400 600 10.2) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 2 solution (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (5.33072e-19 -1.27998e-19 -2.60724e-14) OK. ***High aspect ratio cells found, Max aspect ratio: 2.152e+148, number of cells 336 <<Writing 336 cells with high aspect ratio to set highAspectRatioCells ***Zero or negative face area detected. Minimum area: 0 <<Writing 827 zero area faces to set zeroAreaFaces ***Zero or negative cell volume detected. Minimum negative volume: -1.20141e-17, Number of negative volume cells: 260 <<Writing 260 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 90 average: 6.83007 *Number of severely non-orthogonal (> 70 degrees) faces: 8951. ***Number of non-orthogonality errors: 198. <<Writing 9149 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 13 faces are incorrectly oriented. <<Writing 13 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 5e+150, 710 highly skew faces detected which may impair the quality of the results <<Writing 710 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 6 mesh checks I tried two different meshes done for this simulation and results are the same. I even try to omit these errors and go further with starting the simulation, but it doesn't want to run properly (thats why I am asking for an advice here). After typing solver command, code stops without any error on that point: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _f3950763fe-20191219 OPENFOAM=1912 Arch : "LSB;label=32;scalar=64" Exec : pimpleFoam Date : Jul 21 2021 Time : 19:40:58 Host : DESKTOP-HBV9367 PID : 750 I/O : uncollated Case : /home/mmarczak/myDocuments/Project/cfMeshSingleRotor/case/cfMeshSingleRotor_21_07 nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: solidBody Applying solid body motion to cellZone rotatingZone Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone rotatingZone PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Reading field p Reading field U Reading/calculating face flux field phi Thanks in advance for all hints |
December 21, 2022, 16:21 |
Lucas Cytrangulo
Any updates on this thread?
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
