[mesh manipulation] Splitting the mesh into regions creating a problem |
February 3, 2022, 01:43 |
Sunag R A
Rep Power: 6 |
Dear all,
1. I have created mesh using snappyHexmesh which contains two regions. 2. Now, I used 'setSet' method to convert one patch region into cellZoneSet. 3. Then, I used 'splitMeshRegions -overwrite' to split the mesh into regions, but it creates large amount of domains which are not necessary. What meshing parameters might be the problem? The domain of the region is arbitrary and I have attached an image of two regions after meshing from snappyHexMesh. Image1: Surface with two regions. https://drive.google.com/file/d/1FK1...ew?usp=sharing Image2: Small internal region. https://drive.google.com/file/d/1Ac7...ew?usp=sharing Any leads will be appreciated. Regards, Sunag R A. |
April 14, 2024, 08:53 |
Rep Power: 3 |
Additional option maybe is useful, like -cellZonesOnly
mesh, openfoam, snappy hex mesh, splitmeshregions |
[snappyHexMesh] SnappyHexMesh Internal Mesh problem | tenichols19 | OpenFOAM Meshing & Mesh Conversion | 2 | October 2, 2019 07:39 |
[mesh manipulation] splitting up a mesh in two regions with SHM and setSet | vince_cfd | OpenFOAM Meshing & Mesh Conversion | 0 | September 26, 2019 09:50 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
