[Gmsh] Problem when importing .msh with gmshToFoam |
September 9, 2022, 11:07 |
Rep Power: 3 |
hi,
I have made a mesh with gmsh with two bars. One inside of the other. I would like to perform a conjugated heat transfer analysis. However, when I import the mesh with gmshToFoam I get several warnings of a vertex not being on the boundary of polymesh. This appears to happen because I have defined a patch between the two bars. (In constant/polyMesh/boundary, this patch gets gets 0 faces and it appears has a faceSet). Should I disregard the warnings? Is the mesh not correctly created? The gmsh file is attached bellow. |
Problem in importing Structured mesh from ICEM CFD to ANSYS FLUENT | Aravind M | FLUENT | 0 | August 31, 2020 07:22 |
[ICEM] ICEM CFD Problem with the boundary conditions while importing the mesh to fluent | sonic109 | ANSYS Meshing & Geometry | 2 | September 3, 2014 00:56 |
[Gmsh] gmshToFoam : problem with patch | jmf | OpenFOAM Meshing & Mesh Conversion | 3 | October 4, 2009 16:27 |
gmshToFoam problem | erge | OpenFOAM | 1 | April 23, 2009 11:33 |
Problem of importing the geometry | Dany | CFX | 4 | March 28, 2003 09:49 |
