[Other] Some cellSets generated while some cellSet now size 0
Old   February 15, 2023, 13:36
Default Some cellSets generated while some cellSet now size 0
Eubo is on a distinguished road
Case: I am running a case of buoyantBoussinesqPimpleFoam. It comprises of cuboids in a grid (as shown in the image) Each cuboid has a volumetric heat source on one of it's face, being defined in topoSetDict. I am creating the mesh using blockMesh and later snappyHexMesh
Problem: After running topoSet, all cellSets are created. BUT only partial cellSets have a finite sizes while others have size 0. Through checkMesh The volume bounding box of these cellSets are (1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150).
Mehodology:
>blockMesh >topoSet >surfaceFeatureExtract >snappyHexMesh >checkMesh >buoyantBoussinesqPimpleFoam
Apart from the fact that some cellSets have no size and therefore no heat release, everything else in the simulation was running smoothly. checkMesh was ok and the case hasn't diverged as yet.
Previous debugging attempts: Based on other threads in the forum, I have tried to:
- check the units across dictionaries. Everything is in meters
- added the term 'sourceInfo'. It was working without it too and did not change anything on adding
- verified domain size. The cellSets are within the domain bounds
Questions:
1. Why do some cellSets have size 0. Is it a problem in my topoSetDict?
2. Is it possible to see the sets when I open the mesh in Paraview? how?
topoSet.txt
checkmesh.txt
topoSetDict.txt
Eubo is offline   Reply With Quote
Old   February 19, 2023, 23:41
I was able to solve the issue. I'll describe it here, in case someone faces the same problem in future
Reason behind the issue: blockMesh was creating coarse grid (that was supposed to be later refined by snappyHexMesh), due to which some of my cellZones became smaller than the grid mesh and were not generated at all. Eg. Blockmesh grid was 6*6m, while cellZone depth was 2m.
Solution: Commands run in the following order blockMesh>surfaceFeatureExtract>snappyHexMesh>topo Set. Now, the grid created by snappyhexMesh is much smaller and cellZones of 2m are able to generate.
Hope this helps!
[snappyHexMesh] Cellset now size 0 bruce21 OpenFOAM Meshing & Mesh Conversion 2 February 15, 2023 13:07
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets Struggle_Achieve OpenFOAM Meshing & Mesh Conversion 3 June 17, 2019 09:29
Hydrocyclone simulation and catalogue size problem alexandre.david CFX 8 May 15, 2015 08:40
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
