[mesh manipulation] best approach to cut off part of domain |
January 8, 2024, 01:00 |
Gino Parisella
Rep Power: 9 |
I have generated a set of meshes with a commercial grid generator, and exported to openfoam successfully. Now I would like to modify those meshes to simulate different conditions. The changes "simply" require cutting off part(s) of the domain. As such I am looking for options to obtain this, if even possible. - cut(s) would be made through planes. So I initially thought about using snappyHexMesh, but it doesn't seem to work using searchablePlane - it also popped to my mind to use topoSet and subsetMesh. While I haven't tried it yet, I fear that it would require fiddling around with boundary patches for the exposed cells - alternatively, I thought of using paraview filters, then export as VTK, and convert such VTK to foam Sooo... in your experience, what approach would you pursuit? is it even doable at all? previous threads on the topic went unanswered, here and here. Thanks EDIT: using the paraview approach all boundary patches are lost, i.e. all cells/faces are either internal or default Last edited by ginop; January 8, 2024 at 07:04. Reason: update info about paraview |
January 11, 2024, 01:30 |
M
Rep Power: 12 |
This is untested territory for me, but knowing a few things about how snappy works, I might have a lead for you:
When using any of the searchable regions, you can use them for refinement which is probably the usual way people use them. However, if you add these parts inside the surfaceRefinement { } subdict, create a faceZone, snappy will snap the cells to them. Additionally, if you add a cellZone, you can create regions this way. Once you have regions, you can extract them separately. Now, yet an easier way might be possible in the ESI version of OF. There we have the possibility to provide inside and outside points. So I would go about this by adding the plane as you did. Add an entry for the plane inside the refinementSurfaces subdict and create a faceZone for it to snap the cells which are cut, while supplying a locationInMesh inside the part you want to preserve. Usually, snappy cuts away separate regions which do not have a locationInMesh, so this might be all thats needed. If its remains there, you can try to explicitly remove it: https://www.openfoam.com/documentati...onsOutsideMesh |
January 11, 2024, 03:55 |
Gino Parisella
Rep Power: 9 |
Thanks AtoHM
ok, so I tested the suggestions on a simple mesh, and it works there. I define a searchablePlane as Code:
plane1 { type searchablePlane; planeType pointAndNormal; pointAndNormalDict { point (0 0 -1.); normal (0.1 0 0.9); } } Code:
plane1 { level (0 2); patchInfo { type patch; } faceZone aaa; faceType boundary; //internal; cellZone bbb; cellZoneInside inside; insidePoint (0.1 0.2 -3.3); } After running snappyHexMesh, I run subsetMesh using the region of interest (cellSet) to obtain the new domain. I will try the approach on the actual mesh (much larger in size), and keep you posted about the outcome. Again, thanks a lot for your help! |
PEMFC tutorial case problem | Suleyman41 | FLUENT | 2 | July 15, 2023 11:16 |
[ICEM] a wall part inside the fluid domain | ENIMAB | ANSYS Meshing & Geometry | 3 | July 25, 2022 17:13 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Examining part of a Domain in Pointwise | dilbert | Pointwise & Gridgen | 0 | August 31, 2012 11:37 |
