[CAD formats] Tool for Surface Preparation for SnappyHexMesh
Old   July 27, 2008, 15:35
Default Tool for Surface Preparation for SnappyHexMesh
BastiL
bastil is on a distinguished road
Hi group,
after I tested SnappyHexMEsh I think it is a great tool. What I am still seeking for is a tool to do some preparations on surface (convert iges-geometry to mesh, split surface into parts, name parts, save as stl...)
I am considering tools like blender or gmsh for that. What do others use for this? Any recommendations? Thanks.
bastil is offline   Reply With Quote
Old   July 27, 2008, 22:51
Default Hi, Typically I use blende
Andrew King
andersking is on a distinguished road
Typically I use blender for my geometry creation. Quite good (and fast), once you get used to the interface.
The default stl export from blender is not so great. Especially as binary stl's seem to give one patch per facet in OF-1.5.
I have an ascii stl export script which I will post when its done. Allows ascii export with named objects/surfaces. These names can then be directly used in snappyHexMesh as patches/refinement areas.
Cheers,
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   July 28, 2008, 03:03
Default As far as I know, binary STL c
Francesco Del Citto
fra76 is on a distinguished road
As far as I know, binary STL cannot contain patch names as strings, that's why you have only one patch. You will have the same behaviour if you load that STL into another program, I guess.
Bye,
Francesco
fra76 is offline   Reply With Quote
Old   July 28, 2008, 03:18
Default I haven't actually tried it, b
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I haven't actually tried it, but can't you use other formats instead of stl? Eg, I find the Wavefront .obj quite nice to work with.
Since the type is 'triSurface', I think it should handle any of the supported input formats: stl, gts, obj, off, tri, ac, nas.
olesen is offline   Reply With Quote
Old   July 28, 2008, 06:07
Default Well, that answers my question
Andrew King
Well, that answers my question then ;-).
Anyway I only use stls as that was the best format I could find that was supported by netgen/gmsh and blender. Haven't tried any of the others.
Anyway, I have posted the script in another thread, http://www.cfd-online.com/OpenFOAM_D...5095#POST25114
Cheers,
Andrew
Dr Andrew King
Curtin University
Old   July 28, 2008, 13:15
Default I use Rhino which I found is l
Billy
billy is on a distinguished road
I use Rhino which I found is low cost compared to other CADs. You can download the evaluation version and test it.
If you want something free, maybe you can try FreeCAD.
billy is offline   Reply With Quote
Old   July 28, 2008, 16:58
Default I did some tries with gmsh and
BastiL
I did some tries with gmsh and blender now. Using the motorbike from the tutorials both of them obviously only import the first part of the motorbike. How can these multi-part stls be handled?
Thanks.
Old   July 31, 2008, 07:07
Default Hi all, VTK comes with seve
Elvis
elvis will become famous soon enough
VTK comes with several Reader and Writer libraries for
Wavefront .obj vtkOBJReader http://www.vtk.org/doc/nightly/html/...OBJReader.html
STL (ascii/binary) writer vtkSTLWriter
so converting should be easy
elvis
elvis is offline   Reply With Quote
Old   July 31, 2008, 12:44
Default Hi, MeshLab http://meshlab.
Elvis
MeshLab http://meshlab.sourceforge.net/ might be a good choice for converting from
# import:PLY, STL, OFF, OBJ, 3DS, COLLADA, PTX
to STL
elvis
Old   August 1, 2008, 07:05
Default It depends. If you have an
Billy
It depends.
If you have an IGES or STEP format to begin with, the only free tool I can think of would be based on OpenCASCADE technology. OpenCASCADE has an MFC example for import (IGES, STEP, BREP) and export (IGES, STEP, BREP, STL).
Old   August 1, 2008, 07:47
Default Hi, maybe ls-prepost may be
  #11
mediode
mediode is on a distinguished road
maybe ls-prepost may be of interest for someone. It reads IGS, STP, VDA and couple of others and exports STL (&more) as well (furthermore it can customized).
Dowmload was a bit tricky, check out the googlegroup.
http://www.lstc.com/lspp/
mediode is offline   Reply With Quote
Old   August 3, 2008, 18:01
Default I agree with Billy that having
  #12
BastiL
I agree with Billy that having geometry tools are limited (I see OpenCascade-based Salome and gmsh). However, I have suface meshes in stl (like the motorbike tutorial) and want to regroup or modify it.
Problem with the tutorial for gmsh, Blender and Paraview: I can only import one of the groups... So I do not get he complete motorbike.
Regards.
Old   August 3, 2008, 21:30
Default Hi, If you can't find a to
  #13
Andrew King
If you can't find a tool (and you're a sucker for punishment ;-) ), you can always open up the ascii stl and save each
solid <name>
endsolid
group as a separate file. I think it should be easy to script this. Alternatively you can use admesh ( http://www.varlog.com/index.html ) to convert an ascii stl to binary - this combines the all the groups into one (unfortunately losing all the group information though - see Francesco's post above).
Cheers
Andrew
Dr Andrew King
Curtin University
Old   August 4, 2008, 06:50
Default surfaceSplitByPatch?
  #14
Eugene de Villiers
eugene is on a distinguished road
eugene is offline   Reply With Quote
Old   August 4, 2008, 09:53
Default You might want to take a look
  #15
gocarts's Avatar
Richard Smith
gocarts is on a distinguished road
You might want to take a look at SymLab with its Exchange add-on that imports/exports IGES, STEP and STL. For full geometry creation and meshing control consider the Professional add-on.
The SymLab framework uses OpenCascade as its geometry engine, VTK for visualization and wxWidgets as its cross-platform GUI.
In the works is an OpenFOAM add-on to seamlessly setup, mesh, run and visualize cases within SymLab.
Full Disclosure: I represent Symscape the developer of SymLab.
Symscape, Computational Fluid Dynamics for all
gocarts is offline   Reply With Quote
Old   August 5, 2008, 13:27
Default VariCAD is also a pretty affor
  #16
Billy
VariCAD is also a pretty affordable CAD system for linux:
http://www.varicad.com
I tried ASCON free KOMPAS LT but unfortunately it doesn't have STL export.
http://ascon.net/download.php
Old   August 5, 2008, 13:53
Default This might be also interesting
  #17
Billy
This might be also interesting:
http://www.susqu.edu/facstaff/b/brak...r/evolver.html
It seems to be able to read IGES.
Old   August 5, 2008, 17:16
Default Another option is to use Googl
  #18
Michael Roth
roth is on a distinguished road
Another option is to use Google Sketchup (free):
http://sketchup.google.com/
Then export with the su2stl Sketchup add-on (free):
http://www.crai.archi.fr/RubyLibrary...m_fil_page.htm
roth is offline   Reply With Quote
Old   November 17, 2008, 16:49
Default Hi, I just stumbled on the ne
  #19
David Segersson
segersson is on a distinguished road
I just stumbled on the new CADspan plugin for Sketchup (http://www.cadspan.com/). It seems to be a perfect tool to clean up and export water tight STL-files from Sketchup. They want a small fee for commercial users though.
segersson is offline   Reply With Quote
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) Combas SU2 44 March 12, 2024 00:35
Literature search tool and database jola Main CFD Forum 0 December 4, 2016 13:56
Tool to download: SU2 post-processing Combas SU2 2 June 5, 2014 14:55
Modeling of a Forging Tool. hydro CFX 1 May 19, 2010 18:35
[mesh manipulation] ScalePoints tool cedric_duprat OpenFOAM Meshing & Mesh Conversion 6 September 19, 2008 03:15
