[Commercial meshers] Cell limit
Old   April 14, 2008, 05:35
Default Cell limit
Ryan Middleton
ryan_m is on a distinguished road
I am using OpenFOAM to calculate drag and moment coefficients for an entire aircraft. I am using Gambit for the mesh creation and use fluentMeshToFoam to convert the .msh file. I have had success solving 3D airfoils. However, I have run into a problem when trying to convert an entire aircraft mesh. It has around 40 million cells, and I am wondering if there is a cell limit for OpenFOAM or the fluentMeshToFoam command? I have successfully solved a smaller aircraft with 17 million cells. I have ensured there are no internal walls left undefined in Gambit.
Thanks very much for any help.
Ryan
ryan_m is offline   Reply With Quote
Old   April 14, 2008, 05:47
Default The first limit you will hit i
Hrvoje Jasak
The first limit you will hit is with the integer size (in Gambit, I would guess). You are safe up to approx 768 million cells; for larger meshes, there may be trouble.
Enjoy,
Hrv
Hrvoje Jasak
Compute/Extract cell wall distance Ionut G Fluent UDF and Scheme Programming 0 March 23, 2017 07:05
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 12:25
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
monitoring cell Jane Siemens 2 March 4, 2004 21:01
cell to cell relation CMB Siemens 1 December 4, 2003 04:05
