[Gmsh] GmshToFoam basic question
Old   January 12, 2007, 14:29
Default GmshToFoam basic question
Trinia Dzurny
tdzurny is on a distinguished road
I am attempting to use the gmshToFoam utility for the first time and am getting an error. I was wondering if someone could point me in the right direction. Here is what I did:
(1) Created a new case <gmsh> using FoamX.
(2) Found the file "CubeVer1.msh" that came with the OpenFOAM installation and verified that it could be read by Gmsh.
(3) Copied "CubeVer1.msh" to the root directory of my new <gmsh> case and also copied it to gmsh/constant/polymesh. I wasn't sure if the *.msh file needed to be in the /polymesh directory.
(4) Invoked the gmshToFoam utility from FoamX and from the command line.
Here is the error message I get:
Exec : gmshToFoam /home/tmolls/OpenFOAM/tmolls-1.3/run/test gmsh CubeVer1.msh
Date : Jan 12 2007
Time : 11:17:05
Host : cfd01
PID : 9442
Root : /home/tmolls/OpenFOAM/tmolls-1.3/run/test
Case : gmsh
Nprocs : 1
Create time
--> FOAM FATAL IO ERROR : Attempt to get back from bad stream
file: CubeVer1.msh at line 1.
From function void Istream::getBack(token& t)
in file db/IOstreams/IOstreams/Istream.C at line 44.
FOAM exiting
Can anybody help me out and let me know what I am doing wrong? Thanks in advance.
tdzurny is offline   Reply With Quote
Old   January 12, 2007, 15:09
Default I think it reads the file from
Mattijs Janssens
mattijs is on a distinguished road
I think it reads the file from the current directory. Is the file in there?
mattijs is offline   Reply With Quote
Old   January 12, 2007, 18:34
Default Thanks, your messae got me thi
Trinia Dzurny
Thanks, your messae got me thinking. I found my problem. I needed to include the entire path to the *.msh file in the FoamX dialogue (i.e. the <meshfile> item value needs to include the entire path to the *.msh file). I assumed I just need the file name as long as the *.msh file was in the case directory. At least gmshToFoam reads the *.msh file but I get lots of warnings now and paraFoam crashes when I try to read the converted mesh. So now I have something else to work on.
Thanks
Old   December 3, 2007, 10:22
Default Have you found your error why
Ulrich Naeger
unaeger is on a distinguished road
Have you found your error why paraFoam crashed? I converted my mesh in the same way and it crashes also. So maybe you can give me some hints why.
Thanks
unaeger is offline   Reply With Quote
Basic question on motorBike tutorial newToOpenFoam OpenFOAM Running, Solving & CFD 2 July 14, 2011 09:50
[Gmsh] A basic Gmsh question: 1D transfinite the_phew OpenFOAM Meshing & Mesh Conversion 0 May 10, 2011 10:58
Basic question to buoyantBoussinesqPisoFoam kriz OpenFOAM 2 June 12, 2010 03:35
Basic Question Abhi FLUENT 1 August 4, 2007 08:07
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 19:01
