[Technical] How to get polyhedral mesh without additional cells when using foamToVTK
Old   June 7, 2008, 11:54
Default How to get polyhedral mesh without additional cells when using foamToVTK
Martin/Run DU
chnrdu is on a distinguished road
Send a message via Skype™ to chnrdu
I use salome to generate tetrahedral mesh, then use ideasUnvToFoam to convert this mesh. I wanna use polyhedral mesh to compute some cases, so I use polyDualMesh to convert tetra to polyhedral mesh. That all is fine.
However, when I use foamToVTK to convert foam formated mesh to VTK formated mesh in order to show meshes in paraview 3.3.0, things are different, there are additional cells generated. I use this command:
foamToVTK . sonicLiquidPipeWithSymCylinDamperP100_mseq_poly -time 4.8828125e-06 -allPatches
It said:
Internal : "..../VTK/sonicLiquidPipeWithSymCylinDamperP100_mseq_poly_2. vtk"
Original cells:11079 points:60203 Additional cells:229990 additional points:11066
Combined patches : "..../VTK/allPatches/allPatches_2.vtk"
Combining patches:
patch 0 F1
patch 1 F2
patch 2 F3
patch 3 Walls
End
The boundaries (I load file <allpatches_2.vtk>) are shown correctly. It shows as
but the internal cells are not right, I think. It shows as
I'd like to shown it as real polyhedron without additional cells. How to get it?
rdu
Martin/Run Du
chnrdu is offline   Reply With Quote
Old   June 9, 2008, 03:18
Default As you correctly note, since V
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
As you correctly note, since VTK does not support polyhedral cells directly, foamToVTK tet decomposes polyhedral cells. If you really don't want to see the decomposed cells, you can try with converting to the EnSight format: the newer paraview versions (eg, 3.3 from CVS) manage to read the nfaced (polyhedral) cells and uses a convex point set to display them. This is generally slower than the tet decomposed equivalent and may fail when your cells have concavity. NOTE: the older paraview/VTK versions will segfault if you try to feed them an EnSight file with nfaced cells.
olesen is offline   Reply With Quote
Old   June 9, 2008, 22:29
Default Hi Mark, One question... is
Alexandre Pereira
alexandrepereira is on a distinguished road
Hi Mark,
One question... is there any way to import EnSight format into Paraview without the *%&"#)? "core dump"...?
Should i import it in "Little Endian" or "Big Endian" Format...?
As far i I can recall, Paraview 2.4.4. won't allow it,... Paraview 3.3.0 won't either...downloaded it today from kitware.com...
is there some kind of "trick" to be used in foamToEnsight? or it is just the way things are, not being able to use Paraview with EnSight Format...?
If I use OpenFOAM database format, or VTK export format, lots of streamlines get broken... but if i export it in EnSight Format it gets allright...
... the problem is that my EnSight demo license is almost expiring...
So I am looking for Paraview as one possible alternative...
Best Regards
Alex
Best regards
Alex
alexandrepereira is offline   Reply With Quote
Old   June 10, 2008, 03:43
Default Alex, I've currently broken
Mark Olesen
Alex,
I've currently broken my paraview 3.3 installation, but it did work with polyhedral without a core dump.
If you are using Linux, then the reader will initially read okay, but have the incorrect endian in the GUI. When you click Apply it will cause problems.
Another issue that you may have is that the current VTK EnSight reader incorrectly assumes that all the filenames/times are each on a single line (in the .case file). I submitted a patch, but haven't followed up on it.
Old   June 10, 2008, 13:08
Default Hi Mark, Thanks for this in
Alexandre Pereira
Hi Mark,
Thanks for this info.
Alex
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 11:28
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[snappyHexMesh] sHM too many cells Knapsack OpenFOAM Meshing & Mesh Conversion 2 July 8, 2017 07:41
