[Technical] Cylindrical Pipe with
Old   November 2, 2007, 04:56
Default Cylindrical Pipe with
Luca Liberti
fugu is on a distinguished road
Hi everyone,
I am trying to model a UV unit which is basically a cylindrical pipe with uv tubes in it. The uv tubes are parallel to the average flow direction while the inlet/outlet are located near the top and bottom sections of the unit on the lateral wall of the cylinder.
From what I gathered on the forum it seems that the mesh generation would be quite complicated since I will have to follow the outer pipe geometry while blending towards a pattern that follows the uv tube geometry near them. Does anyone have suggestion on what would be the best tool/method to obtain such a mesh. I would prefer to use only hex elements.
Thanks in advance for any input on the matter.
fugu is offline   Reply With Quote
Specifying heat transfer coeff for a cylindrical pipe Murwin12 FLUENT 3 February 1, 2019 10:34
[Other] Cylindrical Pipe Mesh Generation Shivam Sinha OpenFOAM Meshing & Mesh Conversion 3 November 7, 2014 12:53
Cylindrical Pipe bf3g10 FLUENT 20 February 8, 2013 09:06
Strange velocity profile at the inlet for a flow inside a cylindrical pipe michmich OpenFOAM Running, Solving & CFD 0 July 2, 2012 03:37
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
