[snappyHexMesh] Missing elements near surface with snappyHexMesh
Like Tree1Likes
  • 1 Post By jmf
Old   September 16, 2010, 17:27
Default Missing elements near surface with snappyHexMesh
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Hello everybody
I'm struggling to solve mesh quality problems on the surface of my model : small holes due to missing elements near the model surface.
These holes always occur near transition between patches with different levels
I attached
- a clipped view of flaw in volume
- a view of the surface (from inside the volume) with 3 flaws
- the snappyHexMeshDict
Is the smoothness of the mesh at the surface normal ? I think that it is poor...
I run OF1.7.1 on 64 bit Linux, compiled from sources
Any tip would be appreciated
Regards
J-Michel
jmf is offline   Reply With Quote
Old   September 18, 2010, 06:18
Default Missing cells near surface with snappyHexMesh
jmf
Hello
I go on investigating
This problem only occurs when surface is tilted compared with backgroung hex mesh. I tried 10 and 20 degrees slope. (image attached at 20 degrees)
With surface parallel to background mesh, snappy mesh is smooth (image attached)
The problem is the same with prebuild OF1.6 32 bits
Best wishes
jean-Michel
Old   September 22, 2010, 23:07
ziad is on a distinguished road
Hi Jean-Michel,
Is your geometry smooth enough at these locations? Maybe you could increase the tessellation at these locations in the stl file. It could be a defect in the geometry file.
Otherwise it seems to be a snapping problem. How about increasing nSmoothPatch?
Try running checkMesh -latestTime to see if these elements are not contorted.
Ziad
ziad is offline   Reply With Quote
Old   September 27, 2010, 18:48
jmf
Hi Ziad
Thanks for your answer
I tried increasing nSmoothPatch without result. But then I tried systematic modifications of other Snappy parameters, and finally I found that maxConcave = 90 (instead of 30) solved my problem
Best wishes
Jean-Michel
Propanotriol likes this.
Old   September 27, 2010, 18:55
Originally Posted by jmf View Post
Hi Ziad
Best wishes
Jean-Michel
Thanks for posting the solution Jean-Michel. It's funny but the maxConcave parameter seems to be quite influent on the mesh. I managed to get a mesh without the ragged/jagged edges by reducing maxConcave to 1.0 and it's good to know that it can also fix this type of problems.
Cheers,
Ziad
Old   August 27, 2013, 09:25
Stylianos Kyriacou
Stylianos is on a distinguished road
Thanks for the help guys
Stylianos is offline   Reply With Quote
Old   November 10, 2017, 14:16
Amir Abbas Aliabadi
amir.a.aliabadi is on a distinguished road
Hello Dear All,
I also found that inserting a maxConcave = 90 in the meshQualityControls successfully achieves the snapping part of mesh generations.
Thank You,
Amir A. Aliabadi
amir.a.aliabadi is offline   Reply With Quote
hole, quality, snappyhexmesh, surfaces
[snappyHexMesh] snappyHexMesh can't create refimenet region clktp OpenFOAM Meshing & Mesh Conversion 3 February 27, 2022 09:26
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 05:53
[ANSYS Meshing] missing internal faces and uncovered faces after redifining parts containing surface. grv ANSYS Meshing & Geometry 2 December 9, 2016 04:38
[snappyHexMesh] First try at snappyHexMesh... jaggies, weirdness and missing boundary layers :( KarenRei OpenFOAM Meshing & Mesh Conversion 4 October 15, 2016 19:42
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
