[snappyHexMesh] nonAlignedEdges in snappyHexMesh |
January 11, 2011, 03:24 |
after meshing with SHM and check with checkMesh tool, there is one failure concerning nonALignedEdges. The message after checkMesh is: Number of edges not aligned with or perpendicular to non-empty directions: 241888 <<Writing 216975 points on non-aligned edges to set nonAlignedEdges. Did somebody know how to fix the problem? Regards Daniel |
January 3, 2013, 07:02 |
Stefan
Just stumbled over your question, which is still unanswered. I guess after one year you found a solution. However, as I had the same question there might be others as well, so ...
As I understood from https://sites.google.com/site/snappywiki/snappyhexmesh/cylinder-case, one can ignore this problem. I used such a mesh and OpenFoam did not complain. |
aligned, edges, snappyhex, snappyhexmesh |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
Strange Results With snappyHexMesh | calebamiles | OpenFOAM Running, Solving & CFD | 0 | August 14, 2011 16:02 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
