[blockMesh] run BlockMesh in existing case?
Old   February 24, 2011, 18:55
Default run BlockMesh in existing case?
yu
xiyuqiu is on a distinguished road
Hello all,
I am working with a existing case in OpenFoam 1.6. I am running 1.7. I did the necessary steps to have the case running. I do not if I should run the BlockMesh command or not. At the end I would like to modify the BC and the geometry. I already have a *.neu file and can do the NeutralToFoam command, but do I need to run BlockMesh at some point?
best,
yu
xiyuqiu is offline   Reply With Quote
[snappyHexMesh] can snappy run with multiple block in blockMesh BakedAlmonds OpenFOAM Meshing & Mesh Conversion 9 November 29, 2018 06:30
How to run the 3dTube case in parallel (foam-extend 3.1 with FSI from Zagreb)? Warlord OpenFOAM Running, Solving & CFD 1 January 27, 2018 14:48
chtMultiRegionSimpleFoam planeWall2D case dont run correctly in OPenFOAM 1606+ shengqiming OpenFOAM Running, Solving & CFD 0 August 7, 2016 14:15
Unable to run the case parallel using foam-extend in the cluster farahaqilah OpenFOAM 0 July 27, 2016 23:49
how to map results from steady state run to tranient case? phsieh2005 OpenFOAM Running, Solving & CFD 2 November 7, 2010 06:20
