[Gmsh] Gmsh body of revolution.
Old   April 19, 2011, 14:18
Default Gmsh body of revolution.
Maxim
Sherpa is on a distinguished road
Hello. There's a question more about gmsh. I want to get the geometry of the body of revolution. For example i have a circle and i want to get a sphere rotating that circle. How do i do this? Maybe i'd better use some other programm? I'm slightly new to cfd so i appreciate any help. Thank you.
Sherpa is offline   Reply With Quote
Old   May 10, 2011, 12:31
Maxim
Still have no answer.
Hope someone can give an advice.
Old   May 10, 2011, 15:24
mas222 is on a distinguished road
Sherpa,
Try using the Extrude command in gmsh -- see section 5.1.5 of the online documentation for gmsh 2.5.
Mike
mas222 is offline   Reply With Quote
Old   May 12, 2011, 11:04
Maxim
Mike,
thank you for your reply. I tried it of course, but unfortunately rotating on 2Pi gives me the same line, not the body of revolution, as i want.
Old   May 12, 2011, 12:19
Sherpa,
Try extruding Pi/2 at a time rather than the full 2*Pi in one extrusion....so you'll use four extrusion commands to extrude the full 2*Pi.
Mike
[Gmsh] Gmsh 2D Boundary Layer around a bluff body Pervispasco OpenFOAM Meshing & Mesh Conversion 1 July 6, 2018 09:23
[Gmsh] Converting gmsh to OpenFoam Friendly OpenFOAM Meshing & Mesh Conversion 3 June 26, 2018 05:46
[snappyHexMesh] dynamic mesh: rotating body with increasing/decreasing distance to fixed body mo_na OpenFOAM Meshing & Mesh Conversion 3 July 26, 2016 04:51
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
