May 9, 2011, 03:23 |
Hexahedron 27 nodes
I have a test.geom file to generate a structured hexahedron mesh. If I run gmsh with this option -order 1 I get what I expect that is to say hexadrons with 8 nodes. When I use the option -order 2 I get hexahedrons with 20 nodes. How can I get hexahedrons with 27 nodes ? Thanks a lot |
May 10, 2011, 02:24 |
#2 | |
Mark Olesen
Rep Power: 40 |
In case you didn't notice the gmsh manpage, it describes where all these nodes are located: http://www.manpagez.com/info/gmsh/gm....0/gmsh_60.php Or just google for second-order hexahedron (that's how I found the above manpage), I'm sure you will find something useful there. If not, you'll have to switch to a FEM forum where the people would know something about these types of shape functions. |
32 Cores Mini-Cluster, 2 Nodes vs. 4 Nodes performance | Courageous | Hardware | 3 | July 7, 2016 11:37 |
F_NNODE returns double number of nodes | falkon | Fluent UDF and Scheme Programming | 0 | March 8, 2014 06:58 |
Hexahedron Nodes use in Flow-3D | ck5285 | FLOW-3D | 3 | September 12, 2009 20:30 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
