[Technical] Salome + Gmsh or enGrid for OpenFOAM?
Like Tree1Likes
  • 1 Post By wwrfd
Old   June 22, 2011, 10:27
Default Salome + Gmsh or enGrid for OpenFOAM?
Robin
wwrfd is on a distinguished road
Hi everyone,
I am supposed to make a study on OpenFoam using open-source geometry and meshing software, the studied geometry will be mainly composed of cylindrical shapes. Problem is I've tried many combinaisons between different software like SalomeMeca, Gmsh, enGrid and others and I still don't what could be the best solution between using:
SalomeMeca => Geometry + Mesh and use ideasUnvToFoam to convert the mesh to make the study
SalomeMeca =>Export Geometry STL and then mesh into enGrid or Gmsh and then convert the mesh with gmshToFoam.
I know it exists plenty of other ways to create geometries and meshs but I don't know what is the most appropriate.
I know this subject must have been already discussed about elsewhere and I'm sorry for that.
Thank you for your answers.
Kummi likes this.
wwrfd is offline   Reply With Quote
Old   July 19, 2011, 09:15
Elvis
elvis will become famous soon enough
there is even a third way via pythonflu see link
http://pythonflu.wikidot.com/hybridflu
mentioned in this presentation is http://www.openfoamworkshop.org/6th_...ord_slides.pdf that pythonflu can be used to directly use salome-mesh without converting thru ideasUnvToFoam (that has some limitations and therefore was not a suitable way for Mr. Cliffords work)
elvis is offline   Reply With Quote
Old   July 21, 2011, 10:38
Robin
Ok thank you I will try to use it since I planned to make my geometry and mesh on Salome!
engrid, geometry, gmsh, msh, salomemeca
Error Importing Surface Mesh from GMSH to EnGrid eric.m.tridas enGrid 5 October 4, 2021 03:17
Import this Gmsh .msh file to enGrid ffan enGrid 0 May 5, 2014 12:28
gmsh to Engrid Gora1000 enGrid 0 August 12, 2013 04:08
CAD -> gMsh -> enGrid -> OpenFOAM Problem AlGates OpenFOAM 7 August 6, 2010 12:46
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
