[blockMesh] How can I learn using blockMesh
Old   October 29, 2011, 10:57
Default How can I learn using blockMesh
rawe666 is on a distinguished road
Hello, I am a beginner and I want to learn Openfoam blockMesh. I do not have any experience and I must learn it as soon as possbile since I am working on a project. I saw tutorials from openfoam web page but I do not find them useful. Could you give me suggestions? How can I learn it by myself?
rawe666 is offline   Reply With Quote
Old   November 24, 2011, 03:07
Rik
Rik_Tonnaer is on a distinguished road
Hi Gokhan,
There is no quick and easy way. Try to understand the principle behind the blockMesh utility.
My advice: Start with reading article 2.1.1.1. from the OpenFOAM manual.
http://openfoam.com/docs/user/cavity.php#x5-110002.1.2
Here the most simple blockMesh shape is used -> 1 cube (so 1 block in OpenFOAM terminology). In this article http://openfoam.com/docs/user/blockM...25-1430005.3.1 the full blockMeshDict is explained. So they tell you which sub dictionaries are needed to succesfully run the blockMesh utility.
If you have any specific questions after reading the articles, please let me know!
Good luck!
Rik_Tonnaer is offline   Reply With Quote
Old   November 28, 2011, 05:43
wided
wiedangel is on a distinguished road
Hi Gokhan,
Rik_Tonnaer is right, you should begin by the tutorial on the web page. also it is very important to understand how blockMesh works by applying very simple geometries first, cube, cylider, airfoil ... it is pretty easy and provides very interesting meshes. good luck
wiedangel is offline   Reply With Quote
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 14:54
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
