[OpenFOAM] Question about visualizing XYPlot
Old   June 8, 2006, 04:18
Default Question about visualizing XYPlot
Dihao Tang
tangd is on a distinguished road
If I use "Filter->Probe" in ParaView, then choose "Point" in "Probe Object", I can only see for example a point showing up in the plot(temperature as y axis, time as x axis). But how can I see the temperature curve of this point within a time interval, say 0~0.001s? Thanks!
tangd is offline   Reply With Quote
Old   June 8, 2006, 04:42
Default Hi Dihao. Plots of values ov
Rasmus Hemph
hemph is on a distinguished road
Hi Dihao.
Plots of values over time are not possible in the 2.4.2-version of version of paraview I believe. The cvs-version has temporal plots, so it is soon to come. Your best bet is probably to either create probes in OpenFOAM, or to use vtkProbes on your converted dataset (if you are familiar with VTK).
--Rasmus
hemph is offline   Reply With Quote
Old   June 8, 2006, 06:11
Default Thank you Rasmus. Unfortunat
Dihao Tang
Thank you Rasmus.
Unfortunately, I'm not familiar with VTK at all. I'm wondering how to create probes in OpenFoam, sorry I'm not familiar with this functionality either. Could you please give me further tips? Thank you!
Old   June 8, 2006, 06:42
Default I have not used it myself, but
Rasmus Hemph
I have not used it myself, but there is a sample-utility in OF for probing a data field. Take a look in the User Guide on "Sampling data for plotting graphs".
Old   June 8, 2006, 09:25
Default Thank you for your helpful inf
Dihao Tang
Thank you for your helpful information. I will have a try.
Question about symmetry in Autodesk Cfd 2016 ecto Autodesk Simulation CFD 0 October 20, 2015 04:16
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
