Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
surfaceTransformPoints -rotate
Like Tree3Likes
  • 1 Post By ynos
  • 2 Post By wyldckat
Old   July 11, 2012, 10:28
Default surfaceTransformPoints -rotate
ynos
ynos is on a distinguished road
Dear Foarmers
I have a problem with the next command: surfaceTransformPoints
I can rotate the stl using
surfaceTransformPoints cad.stl cad-r.stl -yawPitchRoll "(0 -5 0)"
but if i want to rotate the stl from another point different (0,0,0), example rotate the stl from to (0 2.5 0) how i can do it.
Thanks in advanced
mo_na likes this.
ynos is offline   Reply With Quote
Old   July 11, 2012, 15:35
Retired Super Moderator
Bruno Santos
Greetings ynos,You'll have to do it in multiple runs. This is because surfaceTransformPoints (as well as transformPoints)was designed to do basic space transformations, one at a time. Additionally, there is (or at least was) a known bug where for rotating 180 degrees it requires that we do 2 runs of 90 degrees each... or something like that.
So - if I understood you correctly - in your case:
  1. Translate points, so that the new origin coincides with the rotation center you want.
  2. Rotate points, as you intended.
  3. Translate back again, using the opposite vector used for the first step.
Best regards,
Bruno
peppino and GregNordin like this.
[GAMBIT] Rotate and revolute possible ? Ijaz ANSYS Meshing & Geometry 19 January 26, 2012 23:36
[ANSYS Meshing] meshing for rotate and revolute Ijaz ANSYS Meshing & Geometry 0 December 25, 2011 16:51
Rotate Hexa Mesh JJ CFX 2 July 14, 2008 05:53
Rotate mesh Bo FLUENT 1 January 10, 2007 16:02
Rotate MEsh Elian81 CFX 0 November 18, 2006 04:51
