foamToVTK ERROR
Old   October 1, 2012, 11:53
Default foamToVTK ERROR
Francesco
Bombolati is on a distinguished road
Hi at all!
I've done a simulation with reactingFoam. Now I've a folder for every writing point that is fixed in the controlDict file. The next step is postprocess the case with paraFoam but I'm working in a parallel environment and there is only paraview installed. So I thought to use the foamToVTK utility to visualize the case with paraview. When I run this utility this error encountered:
--> FOAM FATAL ERROR:
More than one patch accessing the same transform but not of the same sign.
patch:CameraFL1_shadow transform:0 sign:-1 current transforms ( -1 0 0)
From function Foam::label Foam::globalIndexAndTransform::addToTransformIndex
const label,
const label,
const bool
) const
in file lnInclude/globalIndexAndTransformI.H at line 240.
FOAM exiting
I've done the mesh in gambit ad I've exported it with fluent3DMeshToFoam utility. The mesh has some surfaces defined as cyclic, CameraFL1_shadow is one of this.
Someone know how this error encountered?
Thanks a lot.
Bombolati is offline   Reply With Quote
Old   October 1, 2012, 17:21
Retired Super Moderator
Bruno Santos
Greetings Bombolati,
I'm not sure at which level you're doing parallel processing, but if in the cluster you can load the whole case in a single machine for post-processing, then you could use ParaView's internal ".foam" reader. Run this command inside your case folder:
touch case.foam
Then open the "case.foam" file in ParaView. You then have a choice to load either the reconstructed or parallel case.
As for the problem with foamToVTK: did you check the mesh before running the case?
checkMesh -constant
Best regards,
Bruno
Old   October 2, 2012, 04:38
Francesco
Hi Bruno and thanks a lot for you answer. I used the first command to create the file <<case.foam>> and all is ok. Next I tried to use the utility <<check mesh>> and some problems come out. I post here below the result:
Create time
Create polyMesh for time = constant
Time = constant
Mesh stats
faces: 17663239
internal faces: 17406505
cells: 8766526
boundary patches: 20
point zones: 0
face zones: 4
cell zones: 1
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 3640
tet wedges: 0
tetrahedra: 8762886
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
CameraFL2_shadow 9308 4792 ok (non-closed singly connected)
CameraFL2 9308 4792 ok (non-closed singly connected)
CameraFL1_shadow 19082 9725 ok (non-closed singly connected)
CameraFL1 19082 9725 ok (non-closed singly connected)
MixerFL_shadow 1820 1908 ok (non-closed singly connected)
MixerFL 1820 1908 ok (non-closed singly connected)
IniettoreAriaFL_shadow15463 7907 ok (non-closed singly connected)
IniettoreAriaFL 15463 7907 ok (non-closed singly connected)
CameraFSup 40844 20654 ok (non-closed singly connected)
IngAria 12544 6427 ok (non-closed singly connected)
CombIng2 1684 891 ok (non-closed singly connected)
CombIng1 1682 890 ok (non-closed singly connected)
CameraFL 10446 5408 ok (non-closed singly connected)
MixerFint 7254 3817 ok (non-closed singly connected)
MixerFext 11222 5788 ok (non-closed singly connected)
IniettoreAriaFint 12196 6261 ok (non-closed singly connected)
TestaPiano 1959 1040 ok (non-closed singly connected)
IniettoreAriaFext 36654 18584 ok (non-closed singly connected)
Bordo 12707 6474 ok (non-closed singly connected)
CameraFinf 16196 8269 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-1.29063e-15 -2.17066e-14 -7.10543e-15) (98 98 57)
Mesh (non-empty, non-wedge) directions (1 1 1)
Boundary openness (-3.55779e-15 -4.11417e-15 2.20632e-15) OK.
Max cell openness = 3.30458e-16 OK.
Max aspect ratio = 8.87394 OK.
Minumum face area = 0.00211186. Maximum face area = 1.39301. Face area magnitudes OK.
Min volume = 5.43598e-05. Max volume = 0.441604. Total volume = 231604. Cell volumes OK.
Mesh non-orthogonality Max: 67.2498 average: 19.7284
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.954274 OK.
**Error in coupled point location: 45673 faces have their 0th vertex not opposite their coupled equivalent. Average mismatch 38.8115.
<<Writing 45673 faces with incorrectly matched 0th vertex to set coupledFaces
Failed 1 mesh checks.
End
What do you think?
Old   October 2, 2012, 15:58
Bruno Santos
Hi Bombolati,
That is enough proof for me to conclude that this is the reason why foamToVTK is complaining!
You'll find a usage example for fluent3DMeshToFoam: http://openfoamwiki.net/index.php/Fl...y_step_example
As you can see, in that example it also indicates that you should check the mesh after conversion
I'm not familiar with fluent3DMeshToFoam, so my advice is to look in the forum for the keywords:
fluent3DMeshToFoam cyclic
I'm guessing there is a protocol that must be followed for cyclics to be properly converted.
Best regards,
Bruno
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
