Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
different values: yPlusLES functionObject - yPlusLES utility
Like Tree1Likes
  • 1 Post By aylalisa
Old   June 10, 2014, 08:57
Default different values: yPlusLES functionObject - yPlusLES utility
aylalisa is on a distinguished road
Dear Foamers,
I've computed y+ for an LES case (flat channel) with the functionObject type yPlusLES during runtime and, after the computation has finished, with utility yPlusLES. The graphs (plot over line) show y+ values in spanwise (z) direction of the channel.
The first picture shows the results of yPlusLES utility, yPlusLES function Object and y+ computed with class wallDistData for mesh1:
wallDistData<wallPointData<scalar> > y_(mesh, uTau, true);
yPlus = y_*(y_.data()/nuLam);
First picture --> mesh: y-direction, height = 1m, # of cells = 50, mesh refinement (1 2 1)
Second picture --> mesh: y-direction, height = 1m, # of cells = 100, mesh refinement (1 2 1)
Third picture --> mesh: y-direction, height = 1m, # of cells = 150, mesh refinement (1 2 1)
I've assumed that yPlusLES utility and yPlusLES function object imply the same method. The data basis is the same. I don't understand why there is a difference between the results of the two methods.
Why decreases the difference between y+ values of the two methods if I increase the mesh resolution?
Class wallDistData:
Foam::wallDistData<TransferType>::wallDistData
Are there other options for TransferType beside wallPointData. I've expected the same result for y+ by using wallDistData class, too.
Aylalisa
tiam likes this.
aylalisa is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Ensight - node values -cell values leo FLUENT 1 May 12, 2010 08:47
exact face values RubenG Main CFD Forum 0 June 22, 2009 11:09
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
node values or cell values? aPpA FLUENT 0 November 10, 2006 08:56
