binData with pimpleDyMFoam
Like Tree1Likes
  • 1 Post By kkpal
Old   September 1, 2015, 12:26
Default binData with pimpleDyMFoam
kkpal is on a distinguished road
In order to get the span-wise distribution of aerodynamic forces on a circular cylinder subjected to vortex induced vibration, I used the following piece of code in my controlDict
       binData
        nBin        30;          // output data into 30 bins
        direction   (0 0 1);     // bin direction
        cumulative  no;
The cylinder is allowed to move in the transverse direction.
With this code, error soon appears when running with pimpleDyMFoam:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
 at sigaction.c:?
#3  Foam::forces::calcForcesMoment() at ??:?
#4  Foam::forces::write() at ??:?
#5  Foam::OutputFilterFunctionObject<Foam::forces>::execute(bool) at ??:?
#6  Foam::functionObjectList::execute(bool) at ??:?
#7  Foam::Time::run() const at ??:?
 at ??:?
#9  __libc_start_main at ??:?
 at ??:?
After removal of the binData code, pimpleDyMFoam runs well.
Also in the static cylinder case, for which pimpleFoam is used, the binData function works well.
Does binData function not support dynamicMesh?
kkpal is offline   Reply With Quote
Old   October 10, 2015, 09:48
Retired Super Moderator
Bruno Santos
Quick question/answer: Which OpenFOAM version are you using? Because there was a bug related to this in 2.3.0... the bug report: http://www.openfoam.org/mantisbt/view.php?id=1560
Old   October 15, 2015, 02:18
dear Bruno
I'm using OF2.3.0. I will try the later versions. Thanks!
Old   October 23, 2015, 11:02
Yes! OF2.4.0 works well for bindata with pimpleDyMFoam!
wyldckat likes this.
pimpleDyMFoam issue for pitching foil PLD OpenFOAM Running, Solving & CFD 3 May 23, 2017 13:54
pimpleDyMFoam error message laurentb OpenFOAM Running, Solving & CFD 7 May 13, 2015 05:48
Savonius pimpleDyMFoam vitokad OpenFOAM Pre-Processing 10 September 16, 2014 09:30
pimpleDymFoam for tidal turbine Jackie Chen OpenFOAM 6 August 18, 2014 11:09
Error with pimpleDyMFoam samiam1000 OpenFOAM 2 June 11, 2012 06:21
