Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Question about 'postProcess -func'
Old   July 14, 2020, 02:58
Default Question about 'postProcess -func'
Haoran Zhou
Stan Zhou is on a distinguished road
Hi all,
I try to use sampleDict to extract the velocity of several points on my computer but after I execute 'postProcess -func sampleDictU' there is no 'postProcessing' folder. However, on my cluster this command works well.
Is there anything that needed to be done before using the command 'postProcess -func sampledict*'?
By the way, is it the problem caused by different versions? The OpenFOAM I installed on my computer is OpenFOAM-7 and the one on my cluster is OpenFOAM4.0.
Best regards,
Stan
Stan Zhou is offline   Reply With Quote
Old   July 15, 2020, 11:16
clapointe is on a distinguished road
On your local machine no folder is created because it wasn't successful. The way you set up the sample dictionary will likely be different between openfoam versions. In any case here's an example I use for version 7 that works fine :
        libs ("libsampling.so");
        type                    sets;
        writeControl            outputTime;
        writeInterval           1;
        setFormat               raw;
        interpolationScheme     cellPoint;
        fields
	    U
        sets
            line1
                type            lineUniform;
                axis             y;
                start           (0 0 0);
                end             (0 1 0);
                nPoints        10;
Caelan
clapointe is offline   Reply With Quote
Old   July 15, 2020, 22:53
Haoran Zhou
        type                    sets;
        writeInterval           1;
        setFormat               raw;
        fields
	    U
        sets
            line1
                type            lineUniform;
                axis             y;
                start           (0 0 0);
                end             (0 1 0);
                nPoints        10;
Caelan
Thanks for your suggestion. The example also works pretty well on my machine. And I just found that the 'sampling' folder is no longer located in the folder 'applications' and it is in the folder 'src'. I'll look into the differences of sample dictionaries. Thanks again!
Best regards,
Stan
Question about symmetry in Autodesk Cfd 2016 ecto Autodesk Simulation CFD 0 October 20, 2015 04:16
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
