[PyFoam] PyFoamPVSnapshot on pvpython3 not working |
September 22, 2017, 10:06 |
Rep Power: 10 |
First pyFoamVersion output:
Machine info: Linux | Manjaro | 4.9.50-1-MANJARO | #1 SMP PREEMPT Thu Sep 14 09:07:15 UTC 2017 | x86_64 | Python version: 3.6.1 |Continuum Analytics, Inc.| (default, May 11 2017, 13:09:58) [GCC 4.4.7 20120313 (Red Hat 4.4.7-1)] Python executable: /home/robin/miniconda3/bin/python Python 3 is supported with PyFoam PYTHONPATH: /home/robin/miniconda3/lib/python3.6/site-packages:/home/robin/miniconda3/lib/python3.6/site-packages:/home/robin/miniconda3/lib/python3.6/site-packages: Location of this utility: /home/robin/miniconda3/bin/pyFoamVersion.py PyFoam WARNING on line 202 of file /home/robin/miniconda3/lib/python3.6/site-packages/PyFoam/FoamInformation.py : Basedir /home/robin/foam for fork extend does not exist or is not a directory Version 5.0 (reported as number 5.0 )Fork openfoam of the installed 1 versions: openfoam-5.0 : /home/robin/OpenFOAM/OpenFOAM-5.0 pyFoam-Version: 0.6.8.1 Path where PyFoam was found (PyFoam.__path__) is ['/home/robin/miniconda3/lib/python3.6/site-packages/PyFoam'] Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/robin/.pyFoam/pyfoamrc'), ('directory', '/home/robin/.pyFoam/pyfoamrc.d')] Configuration files (used): [] Installed libraries: cython : No Not used. Maybe will by used later to spped up parts of PyFoam cProfile : Yes docutils : No Not necessary. Needed for RestructuredText to HTML conversion Gnuplot : No Not a problem. Version from ThirdParty is used hotshot : No Not a problem. Can't profile using this library line_profiler : No Not a problem. Can't profile using this library ipdb : No Not necessary. Only makes debugging more comfortable IPython : Yes version: 6.1.0 Matches required version 2.0.0 matplotlib : Yes version: 2.0.2 mercurial : No Not a problem. Used for experimental case handling pytest : No Only needed for running the unit-tests (developers only) numpy : Yes version: 1.13.1 openpyxl : No Not a problem. Only used for exporting pandas-data to Excel-files (advanced). If xlsxwriter is installed it will handle this (xlsxwriter is recommended anyway) xlsxwriter : No Not a problem. Only used for exporting pandas-data to XLSX-files (advanced). If openpyxl is installed then this module can handle that pandas : Yes version: 0.20.3 ply : No Not a problem. Version from ThirdParty is used profile : Yes psyco : No Not a problem. Acceleration not possible PyQt4 : No Only some experimental GUI-stuff relies on this PyQt4.Qwt5 : No Only an alternate plotting back-end scipy : No Not yet used. Possibly use signal-fitting etc Tkinter : No Not a problem. Used for the old version of DisplayBlockmesh and some matplotlib-implementations twisted : No Not yet used. Possibly reimplement MetaServer with it vtk : No Not a problem. Only used for some utilities xlwt : No Not a problem. Only used for exporting pandas-data to Excel-files xlrd : No Not a problem. Only used for importing Excel-files to pandas-data requests : Yes version: 2.14.2 zeroconf : No Not a problem. Necessary to find existing runs. Install with 'pip install zeroconf' psutil : Yes version: 5.2.2 PyFoam.ThirdParty.ply.yacc : Yes version: 3.9 PyFoam.ThirdParty.Gnuplot : Yes version: 1.8 PyFoam.ThirdParty.tqdm : Yes version: 4.8.4 PyFoam.ThirdParty.IPy : Syntax Error This is our own. If it is not found we've got problems PyFoam.ThirdParty.pyratemp : Yes version: 0.2.0 PyFoam.ThirdParty.six : Yes version: 1.10.0 PyFoam.ThirdParty.winhacks : Yes Library locations cProfile : /home/robin/miniconda3/lib/python3.6/cProfile.py IPython : /home/robin/miniconda3/lib/python3.6/site-packages/IPython/__init__.py matplotlib : /home/robin/miniconda3/lib/python3.6/site-packages/matplotlib/__init__.py numpy : /home/robin/miniconda3/lib/python3.6/site-packages/numpy/__init__.py pandas : /home/robin/miniconda3/lib/python3.6/site-packages/pandas/__init__.py profile : /home/robin/miniconda3/lib/python3.6/profile.py psutil : /home/robin/miniconda3/lib/python3.6/site-packages/psutil/__init__.py PyFoam.ThirdParty.Gnuplot : /home/robin/miniconda3/lib/python3.6/site-packages/PyFoam/ThirdParty/Gnuplot/__init__.py PyFoam.ThirdParty.ply.yacc : /home/robin/miniconda3/lib/python3.6/site-packages/PyFoam/ThirdParty/ply/yacc.py PyFoam.ThirdParty.pyratemp : /home/robin/miniconda3/lib/python3.6/site-packages/PyFoam/ThirdParty/pyratemp.py PyFoam.ThirdParty.six : /home/robin/miniconda3/lib/python3.6/site-packages/PyFoam/ThirdParty/six.py PyFoam.ThirdParty.tqdm : /home/robin/miniconda3/lib/python3.6/site-packages/PyFoam/ThirdParty/tqdm/__init__.py PyFoam.ThirdParty.winhacks : /home/robin/miniconda3/lib/python3.6/site-packages/PyFoam/ThirdParty/winhacks.py requests : /home/robin/miniconda3/lib/python3.6/site-packages/requests/__init__.py Checking additional envirnoment variables Checking for PYFOAM_DIR : Location of the PyFoam-installation. Not strictly necessary PYFOAM_DIR missing from environment Checking for PYFOAM_SITE_DIR : Location of non-PyFoam-disctributions script. Set and used by some Foam-distributions PYFOAM_SITE_DIR missing from environment User information Username: robin Temporary directory: /tmp/PyFoam_robin Public key: 795500f7c541b97d32365f7537a3f4df:7cadac11f31d33ff0e420510181b1edf If I run pyFoamPVSnapshot.py: Code:
Executing PVSnapshot with pvpython trough a proxy-script options: Traceback (most recent call last): File "/tmp/pyFoamPVSnapshot_7ow4923h.py", line 2, in <module> from PyFoam.Applications.PVSnapshot import PVSnapshot File "/home/robin/miniconda3/lib/python3.6/site-packages/PyFoam/Applications/PVSnapshot.py", line 240 print "Say:", ^ SyntaxError: Missing parentheses in call to 'print' Error: Return code 1 executing /tmp/pyFoamPVSnapshot_7ow4923h.py print("Say:", end="") then the following output: Code:
Executing PVSnapshot with pvpython trough a proxy-script options: Traceback (most recent call last): File "/tmp/pyFoamPVSnapshot_ctwjfyoc.py", line 2, in <module> from PyFoam.Applications.PVSnapshot import PVSnapshot File "/home/robin/miniconda3/lib/python3.6/site-packages/PyFoam/Applications/PVSnapshot.py", line 8, in <module> from PyFoamApplication import PyFoamApplication ModuleNotFoundError: No module named 'PyFoamApplication' Error: Return code 1 executing /tmp/pyFoamPVSnapshot_ctwjfyoc.py So, how to solve this? This should not happen at all, should it? |
pyfoam |
Processor 0 not working | vishwesh | OpenFOAM Running, Solving & CFD | 0 | November 17, 2017 03:35 |
[PyFoam] Problem with pyFoamPVSnapshot | Pavel Rodin | OpenFOAM Community Contributions | 7 | September 27, 2017 06:30 |
Coal gasification: reactions not working | shabbarraza2000 | FLUENT | 9 | May 29, 2017 05:10 |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 02:01 |
Working directory | mgonzalo | FLUENT | 1 | November 11, 2011 10:05 |
