Age of air with function object
Like Tree1Likes
  • 1 Post By Rojj
Old   April 14, 2018, 12:07
Default Age of air with function object
Ruggiero Guida
Rojj is on a distinguished road
I have added a function object to calculate the Age Of Air in OF4.1. SimpleFoam converges, but I have some doubt about the interpretation of the results.
I have based the implementation on this thread
Mean Age of Air
In my controlDict I have added the following function
AoA
    type    scalarTransport;
    functionObjectLibs ("libutilityFunctionObjects.so");
    enabled true;
    writeControl outputTime;
    log yes;
    nCorr 1;
    field AoA;
    active          true;
    autoSchemes     false;
    resetOnStartUp false;
    DT              1e-5;
    fvOptions
        IncrementTime
            type            scalarSemiImplicitSource;
            active          true;
            scalarSemiImplicitSourceCoeffs
                selectionMode all;
                volumeMode  specific;
                injectionRateSuSp
                    AoA       (1 0);
I have then added the following boundary condition
dimensions [ 0 0 1 0 0 0 0 ];
internalField uniform 0.0;
boundaryField
  inlet
    type fixedValue;
    value uniform 0;
  outlet
    type zeroGradient;
Modified fvSchemes and fvSolution accordingly with
div(phi,AoA) bounded Gauss upwind;
and
    AoA
        solver           smoothSolver;
        smoother         GaussSeidel;
        tolerance        1e-08;
        relTol           0.1;
        nsweep                   1;
The solution converges, but I am not really sure I get what it means. My understanding is:
  • We inject some kind of tracer at each point of the domain
  • We assign uniform zero as BC
  • The value of AoA tells us how long, in average, it will take for the air in that point to be replaced by new air coming from the boundary (outside)
  • This is why we assign uniform 0 at the boundary
Is this correct?
What does IncrementTime actually do?
Why AoA has unit of Time?
Why we inject 1 of tracer?
pemesu likes this.
Rojj is offline   Reply With Quote
Old   February 7, 2021, 13:49
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
It took me three years to reflect on these questions (kidding)
(maybe not)
Age of Air Function Object
HPE is offline   Reply With Quote
Old   November 8, 2022, 08:24
gabriel rodrigues
Lucc is on a distinguished road
Have you found out the answer for these questions?I've been facing the same problem.
Lucc is offline   Reply With Quote
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 11:32
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
coded function object and field average matthias OpenFOAM Post-Processing 3 June 30, 2014 04:52
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
