Plotting Q-criterion
Like Tree4Likes
  • 1 Post By akidess
  • 3 Post By LuckyTran
Old   January 16, 2019, 09:42
Default Plotting Q-criterion
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
Hi.
I'd like to visualize spots with dissipation losses in my domain (a transient k-omega SST pimpleFoam case with dynamic mesh). I have the following options:
  • stream tracer (shows where vortexes are but streamlines end on AMI patches)
  • vorticity plot (not sure what that shows, though)
  • Q-criterion iso-surfaces
  • Entropy calculation (https://www.mdpi.com/1099-4300/16/6/2959)
I have found many examples of Q-criterion but my problem is that the values range from say -1e+17 to +1e+17. How do I choose values for isosurface plots so that they give me the most information?
Thanks!
kandelabr is offline   Reply With Quote
Old   January 16, 2019, 09:51
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
AFAIK there is no real way to chose the value for the isosurface - you choose what looks good (see [1]). However, your value range seems unbounded, which makes me believe you may have a small error in your computation.
[1] Dubief, Y., Delcayre, F., 2000. On coherent-vortex identification in turbulence. Journal of Turbulence 1.
URL http://dx.doi.org/10.1088/1468-5248/1/1/011
lukasf likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   January 16, 2019, 15:58
kandelabr's Avatar
Nejc
Thanks for the reply.
Actually the values are more like -1e+7 to 1e+7; does that make any difference? What range should Q-criterion usually be in?
Old   February 18, 2019, 11:07
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
The range of Q-criterion is normally some finite negative number to positive infinity. That you have a nice symmetric negative 1e7 and positive 1e7 suggests you might have some bug. But it might still be correct. Anyway, just check.
The isosurface of Q-criterion you should plot is "some positive number that you like" Q-criterion is also dimensional in its pure definition, so one type of flow you take Q=1 and another type of flow you might take Q = 1000. You could normalize the Q-criterion to help with this. But because this is so hard to decide (it's quite arbitary what this threshold is), the closely related lambda 2 criterion is often preferred over Q-criterion (where the threshold is 0).
LuckyTran is offline   Reply With Quote
Old   February 18, 2019, 16:14
kandelabr's Avatar
Nejc
Lambda2, you say.
Never heard of that, will try out, thanks a lot!
www.damogranlabs.com
Old   February 19, 2019, 04:20
akidess's Avatar
Anton Kidess
The paper I linked in my post a month ago also explains the lambda2 criterion.
Old   February 19, 2019, 07:54
kandelabr's Avatar
Nejc
...but unfortunately isn't available without paid access.
Old   September 11, 2020, 11:01
MA
mazhar16823 is on a distinguished road
Hi LuckyTran,
I am struggling with the same. Although I have created Q-criterion but half of the blade is taken away (maybe due to the flow separation) however I have to compare my RANSE Q-Criterion (STARCCM) with reference Q-Criterion (LES)as you can see in the attached images. Why the half of blade is taken away, is there anyway to fix this issue and represent the whole Q-criterion on the blade surface?
mazhar16823 is offline   Reply With Quote
[General] 3D plot Q criterion Ursmooth ParaView 1 November 25, 2021 14:42
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
[ANSYS Meshing] 'Element quality' meshing criterion RobBanks ANSYS Meshing & Geometry 2 May 2, 2018 12:21
Stopping criterion for outer iteration loop luftraudi Main CFD Forum 3 February 22, 2017 08:59
Asymptotic stopping criterion is not working rob50904 STAR-CCM+ 2 January 28, 2013 08:25
