Calculate shear stress in a laminar fluid flow using simpleFoam
Old   April 16, 2019, 15:35
Red face Calculate shear stress in a laminar fluid flow using simpleFoam
Diego Menezes Pamplona
dieg01mp is on a distinguished road
I'm trying to obtain the shear stress from a flow on a rectangular passage with a cylindrical obstacle in the middle. Something like that on the picture. I saw some people on other posts saying that you can use the command wallShearStress to do the trick, but every time I try, I receive a message telling that the command is not recognized. Now, I don't know if there were some changes in the newer versions, or maybe I have to import some wallShearStress file to the system folder first, but I can't figure it out.
I'm definitely an OpenFOAM newbie, so if I'm not giving enough information, please let me know.
dieg01mp is offline   Reply With Quote
Old   April 23, 2019, 10:06
Default post processing wss
YCarv is on a distinguished road
Hello Diego,
did you try doing:
simpleFoam -postProcess -func wallShearStress
after running your case?
YCarv is offline   Reply With Quote
Old   April 23, 2019, 14:07
Talking Thanks
Yes. I have already tried it after much more digging through some other threads and it worked out beautifully. But i still dont know if this is the right WSS, because i read somewhere that the one that is computed in openFOAM is the WSS written on kinematic pressure dimensions, that is, as if we were calculating the WSS using the kinematic viscosity instead of the dynamic one.
And besides, if someone have a tip on how to deal with .dat information, like ploting curves and this sort of stuff, i would be really grateful. As i already am actually, thanks.
Old   October 14, 2019, 07:28
Default Post processing / data plotting
Sourav Mandal
sourav90 is on a distinguished road
You can use tools like gnu plot. One such example for monitoring residuals in combination with`foamMonitor`:
Monitoring residuals
sourav90 is offline   Reply With Quote
Old   October 14, 2019, 08:00
Carlo_P
Carlo_P is on a distinguished road
Hey Diego,
did you try to use:
functions
#includeFunc wallShearStress}
in the controlDict?
Otherwise, just to do as test, you can try simpleFoam -postProcess -list and check if wallShearStress is present.
Otherwise, try to turbolent, also if should not be this one the problem.
Last, reinstall OpenFOAM.
Carlo_P is offline   Reply With Quote
Shear stress induced on fluid in centrifugal pump MechKim CFX 2 September 30, 2016 11:39
How to calculate Reynolds shear stress of a fully turbulent channel flow yansheng STAR-CCM+ 1 March 8, 2016 17:35
Shear stress fluctuations by turbulent flow Meegao FLUENT 0 October 11, 2012 05:54
Do formula for Laminar and Turbulent Flow Calculation formulae change with Fluid Parag Gadgil FLUENT 0 June 19, 2012 07:07
Fluid wall shear stress Sinead Kelly (Kelly) OpenFOAM Running, Solving & CFD 2 March 30, 2011 06:41
