July 31, 2023, 03:26 |
#21 | |
it's helpful. Thanks a lot!!! |
July 31, 2023, 05:21 |
#22 | |
Josh Williams
Rep Power: 5 |
You can copy the code in the IO C file, where a particle field is defined such as p.UTurb() and add similar code for p.position(). |
July 31, 2023, 11:30 |
#23 | |
Conor Crickmore
Rep Power: 6 |
Hey Xhan, I'm glad you sorted it! Figured I'd post a link to my GitHub repository that includes these changes as well as others, in case they are of use to you, or anyone else: https://github.com/ttcjc/OpenFOAM/tree/dev
Conor Crickmore PhD Researcher in Automotive Aerodynamics Aeronautical and Automotive Engineering Loughborough University LE11 3TU |
Lagrangian particle position data at runtime | vishwesh | OpenFOAM Programming & Development | 3 | July 11, 2018 09:48 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Tecplot reading particle data error | ali hemmati | FLUENT | 1 | February 13, 2016 06:17 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 03:02 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
