How to extract the data of all cells in the domain |
Bssam
Rep Power: 3 ![]() |
Hi
It is a simple question. Suppose that we have a 2D domain That consists of 9 cells for example (imagine a square of 9 cells) Then I want to extract the data of the temperature field at each cell and the corresponding data of another field (say mixture fraction Z) in that way I have the full data of each cell in terms of (Tcell,Zcell) How to do this? |
Herpes Free Engineer
Rep Power: 8 ![]() |
I am not sure if I understood your question, so my apologies.
Information within a numerical domain can be interrogated by many means in OpenFOAM: e.g. sample, and probe utilities. Please do search them.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak-FSB OpenFOAM Governance and Technical Committees Report bugs/Request features: OpenFOAM (ESI-OpenCFD-Trademark) Report bugs/Request features: FOAM-Extend (Wikki-FSB) Report bugs: OpenFOAM.org How to create a MWE. OF Journal OFv2012 |
Bssam
Amazing that really worked. To extract the whole information of the field in a mesh: select > filter > data analysis > probe location > press ok whatever the settings are > then chang the tab "showing" and select your mesh. Finally, save in a csv file.
All the best |
Yan Zhang
If I correctly understand your demand, there is a utility to deal with such things in my GitHub:
https://github.com/ZhangYanTJU/foam2Columns It supports any number of fields and transforms them to this format: Code:
L1: x y z var1 var2 ... L2: x y z var1 var2 ... . . . Ln: x y z var1 var2 ... Code:
foam2Columns -fields "(p T)"
https://openfoam.top |
#5 | |
Bssam
What an elegant function is this! That exactly what I meant. Also, this function does more than I need which it also specifies the location x y z. The method I mentioned in my comment also works but it is not as easy as this function! So awesome, I will give it a try for sure 👌🏻 |
Bssam
That is why I like OpenFOAM. The room for improvement is endless! And collaboration is very effective in the scientific community 🙏
abdikerim kurbanaliev
Rep Power: 12 ![]() |
Dear zhangyan,
I downloaded foam2Columns into home/run folder. After unzipping and compiling I used it for dambreak case. Using the foam2Columns -fields "(p_rgh)" gives me all info that was proposed. But the execution of the foam2Columns -fields "(alfa.water)" gives nothing. In another words everything is fine for p_rgh? not for alfa.water. I am using openfoam 7 on ubuntu 16.04 LTS Any kind of help is highly appreciated. Kerim |
#8 | |
Yan Zhang
1. Did you type it right? Isn't it alpha.water? 2. Now the foam2Cloumns tool only supports for volScalarField. Is alpha.water a volScalarField?
#9 | |
1. Yes I did it right. 2. alfa.water is volScalarField. By the way, after execution of the command foam2Columns -fields "(alfa.water)" in the terminal I got a file alphaPhi0.water. But it is not that file I am looking for. Frakly speaking I don't understand what kind of file I got. Please see attachments for more information. Kerim alfa.water.jpg alfa.water1.jpg alfa.water2.jpg alphaPhi0.water.jpg p_rgh.jpg |
#10 |
Dear zhangyan,
I just used foam2Cloumns tool for bouyantCavity case which uses buoyantSimpleFoam solver. Direct application of foam2Cloumns tool gives an error keyword PIMPLE is undefined in dictionary "/home/kerim/run/buoyantCavity/system/fvSolution". As you know buoyantSimpleFoam solver use only SIMPLE, not PIMPLE. After changing SIMPLE to PIMPLE I got foam2Columns_p_T file. That is what I was looking for. Could you explain me why do I have above mentioned error? Kerim bouyantCavity-1.jpg bouyanCavity-2.jpg |
#11 | |
Yan Zhang
But I found it from the last picture, at 0.5 s, you only got alpha.water. I don't know why you want to try alfa.water.
#12 | |
Yan Zhang
It will give me a chance to improve this tool. I'll check it soon.
#13 | |
Mark Olesen
Rep Power: 28 ![]() ![]() |
https://www.openfoam.com/documentati...t.html#details |
#14 | |
Dear Zhangyan, Alfa.water helps to determine the position of free surface between two fluids - water and air. The value of alfa.water=.05 represents free surface and that is why I need to extract from OpenFOAM alfa.water by using foam2Columns tool. Kerim |
#15 |
#16 | |
Yan Zhang
foam2Columns -fields "(alpha.water)
#17 | |
Dear Zhangyan, Right now I have reinstalled ubuntu 16.04.6 LTS 64 bit, OpenFoam 7 and foam2Columns. Than I copied alpha.water from 0 folder and pasted in terminal. After execution of the command foam2Columns -fields "(alpha.water)" I got foam2Columns_alpha.water file I was looking for. Frankly speaking I don't understand of the reason of my previous mistakes. Now everything is OK with foam2Columns tool. Please see the attached figures. Thanks a lot to you. Your help is highly appreciated. It will be great to expand foam2Columns for volVectorField quantity like velocity. Kerim alpha.water-1.jpg alpha.water-2.jpg alpha.water-3.jpg alpha.water-4.jpg picture-wmake.jpg |
#18 | |
Yan Zhang
Now it supports for volVectorField! https://github.com/ZhangYanTJU/foam2Columns Quote:
#19 | |
Thanks a lot to you. Your help will be highly appreciated bythe OpenFOAM community. |
#20 | |
I am wondering if foam2Columns works for OpenFOAM v6. I tried to compile the code with wmake but I got the below error. Code:
Making dependency list for source file foam2Columns.C g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam6/src/finiteVolume/lnInclude -I/opt/openfoam6/src/meshTools/lnInclude -I/opt/openfoam6/src/sampling/lnInclude -I/opt/openfoam6/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/opt/openfoam6/src/OpenFOAM/lnInclude -I/opt/openfoam6/src/OSspecific/POSIX/lnInclude -fPIC -c foam2Columns.C -o Make/linux64GccDPInt32Opt/foam2Columns.o foam2Columns.C: In function ‘int main(int, char**)’: foam2Columns.C:109:21: error: ‘fileType’ has not been declared fileType::directory ^~~~~~~~ /opt/openfoam6/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/foam2Columns.o' failed make: *** [Make/linux64GccDPInt32Opt/foam2Columns.o] Error 1 |
Display Modes | |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 90 | October 3, 2019 08:01 |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 10 | August 5, 2019 20:18 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM Running, Solving & CFD | 6 | January 25, 2019 01:11 |
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 19 | January 8, 2019 11:56 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
