October 27, 2020, 07:52 |
sample custon surface
hulli graemer
Rep Power: 11 |
does anybody know how to postprocess a surface that is smaller than my model extends. Basically I want to produce a custom slice through my model, sililar to paraview but without paraview. However, I do not succeed with the expression below using the sampleDict / surfaceDict... Any ideas yCut { // Cutingplane using iso surface type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { basePoint (0.01 0.01 0.01); normalVector (0.0 0.00 1); // zone (zone1); } interpolate false; } |
October 27, 2020, 15:26 |
Rep Power: 8 |
Do you use OpenFoam v8? If that's the case, maybe you could use topoSet with planeToFaceZone and faceZoneAverage to achieve what you want.
October 28, 2020, 03:38 |
hulli graemer
Rep Power: 11 |
Hi, thanks ... So for now I was running OF5x so I will try that with OF 8 ... I`ll keep you in the loop
October 30, 2020, 02:51 |
surface
hulli graemer
Rep Power: 11 |
actually I have not been able to manage that ... It sucks somewhat because my model is so heavy in terms of memory, so the postprocess with paraview is actually not the way to go ... May be someone else has an idea ... I just want to corp a slice ... I also tired that by using a stl but then I only get the intersection between my field and the stl which is not what I want ... Any other sugestions ??? |
November 7, 2020, 04:58 |
#5 | |
Mark Olesen
Rep Power: 40 |
In end effect this causes a cell cutting much like the sampling plane does. |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
area averaged pressure of sample surface | FerdiFuchs | OpenFOAM Post-Processing | 1 | October 24, 2014 09:50 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
