November 25, 2020, 11:27 |
cuttingPlane weightedAreaAverage
Javier Vinuales
Rep Power: 9 |
Hi everyone,
I am using OpenFOAM v2006. I need to calculate the mass flow average at different cross-sections of a duct. I was thinking to use a cuttingPlane to do so. How can I do it? I tried to use the following but function object but I got an error: Code:
tempX1Average { type surfaceFieldValue; libs ("libfieldFunctionObjects.so"); writeControl writeTime; fields (T); writeFields no; // yes | no regionType sampledSurface; name test; sampledSurfaceDict { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { basePoint (0 0 0); normalVector (1 0 0); } } operation weightedAreaAverage; weightField phi; } --> FOAM FATAL IO ERROR: Cannot use weighted operation 'weightedAreaAverage' for sampledSurface Is there a way to calculate a mass flow average temparature at a cutting plane? |
Sampling air passing through multiple windows | b.simpson | OpenFOAM Post-Processing | 3 | September 4, 2020 08:07 |
Sampling fields values passing through multiple windows | b.simpson | OpenFOAM Post-Processing | 0 | May 1, 2020 11:14 |
cuttingPlane with cyclic BC | Xulia | OpenFOAM Post-Processing | 1 | April 26, 2016 07:27 |
export calculated variable with cuttingPlane | Eloise | OpenFOAM Post-Processing | 0 | June 16, 2014 10:59 |
How to plot variable (alpha1) on cuttingPlane (runtime postprocessing) | pythag0ra5 | OpenFOAM Post-Processing | 1 | September 26, 2013 08:46 |
