Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Question for setting User Defined Variables at runtime for monitoring
Old   January 31, 2021, 17:35
Default Question for setting User Defined Variables at runtime for monitoring
Donghun Kang
Paul_AERO is on a distinguished road
Greetings,
I am a beginner of OF. I have trouble compiling user defined variable (pprime) in the system/controldict. (version: v2012)
functions
pprime
type coded;
libs (utilityFunctionObjects);
name pprime;
writeControl timeStep;
writeInterval 1;
codeWrite //(or codeExecute)
const volScalarField& p = mesh().lookupObject<volScalarField>("p");
const volVectorField& U = mesh().lookupObject<volVectorField>("U");
volScalarField pprime
IOobject
"pprime",
mesh().time().timeName(),
p.mesh(),
IOobject::NO_READ,
IOobject::AUTO_WRITE
p
pprime=p-101325;
fields
pprime
base time;
I referred to Create registered object at runtime using a functionObject
But mine does not work, showing:
--> Could not load "...
Before running, is there any command to compile?
My current sequence to simulate is mpirun -np 16 rhoPimpleFoam -parallel
Thanks,
Paul
Paul_AERO is offline   Reply With Quote
Old   February 9, 2021, 17:56
clapointe is on a distinguished road
Without seeing the full error it is hard to help. However, if we check out the codedFunctionObject.H file, we find the following template :
        type coded;
        // Name of on-the-fly generated functionObject
        name writeMagU;
        codeWrite
            // Lookup U
            // Write
            mag(U)().write();
So if we update this for your case, we get :
    pprime
        type coded;
        name writePPrime;
        codeWrite
            // Lookup p, name pprime
            const volScalarField& pprime = mesh().lookupObject<volScalarField>("p");
            //Update pprime
            pprime -= dimensionedScalar("refP", pprime.dimensions(), 101325);
            // Write
            pprime.write();
Note that I've not tested the above code, but if it doesn't work out of the box hopefully it'll point you in the right direction.
Caelan
clapointe is offline   Reply With Quote
Old   September 7, 2021, 17:43
Donghun Kang
Thanks Caelan!
I have resolved that issue
Paul
UDF value to large for defined data type Anna73 Fluent UDF and Scheme Programming 9 September 30, 2018 22:18
Read Result Files or User Defined Result Aquilaris ANSYS 0 February 9, 2011 05:25
User Defined Scalar (UDS) question (units) D FLUENT 0 March 1, 2006 20:04
Usage of user defined functions Gowrish FLUENT 1 October 26, 2005 07:44
User defined memory Hp FLUENT 0 September 24, 2004 00:10
