Problem manipulating Data in Tecplot after foamToTecplot Conversion |
June 4, 2008, 12:58 |
Hi Guys,
I am starting to u
Hi Guys,
I am starting to use openFoam, and as a test I am studing the flow in a sudden expansion, in 2D. To the post-processing, I use the foamToTecplot to convert the results and to treat them in Tecplot. I can convert the data, represent the results using contours. But, when I try to create some stream lines, I got the error "Data is FE Brick or Tetrahedron. It is best to use 3D". I can do some stream lines in 3D, but it is awkward. Thanks, António Martins |
June 6, 2008, 10:30 |
Data>Extract>slice from plane
Aditya Chunekar
Although 2D, openfoam extrudes it in z. so slice a plane at constant z. Go to zone style and activate the newly formed slice and deactivate the original 3d. view the result as 2D cartesian. |
June 10, 2010, 04:23 |
Pavan
Thanks for that info. In the case of a transient solution you need to select 'extract slices over time' - which will give you the same option for each time-step.
It would be wonderful if a tool for FoamToTecplot is available | luckyluke | OpenFOAM Post-Processing | 165 | November 27, 2012 06:54 |
Unstructured data with Tecplot | Andreas | Tecplot | 3 | August 12, 2008 05:30 |
tecplot data format | Harry | Tecplot | 0 | June 24, 2006 17:32 |
manipulating post data | Brad | Siemens | 1 | June 13, 2002 10:03 |
how to get data tecplot can utilize? | Pete Chen | Siemens | 8 | May 31, 2000 06:00 |
