Special BC
Old   May 9, 2013, 08:31
Default Special BC
Tobi's Avatar
Tobias Holzmann
i am trying to simulate a baffle that is closed the first 60 sec. then it opens for the fluid for 60 sec and so on.
There for I wanted to use a sin - function like that:
sin (xxxx) > 0 -> baffle open
sin (xxxx) < 0 -> baffle closed
In that case it should be possible to use groovyBC is that correct?
Further more is it possible to solve that problem with an steady-state solver?
And finally - what patchtype should it be?
wall
patch
cyclic
In my opinion it could be a patch type
Thanks in advance tobi
Old   May 9, 2013, 12:14
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
You can accomplish the same thing with attachDetach mesh modifier. This requires to have a new topoChangerFvMesh; you can probably use the one I submitted for this bug report:
http://www.openfoam.org/mantisbt/view.php?id=572
Make sure you make the change mentioned in the third to last note about creating a new pointfield and then moving the points.
This is working in both 1.6-ext and 2.2.x.
mturcios777 is offline   Reply With Quote
PISO algorithm for particular NS equation (special convection term) Cyp OpenFOAM Programming & Development 8 June 12, 2012 09:36
Special boundary for multiphase flows Michael B FLUENT 0 June 7, 2007 04:30
help for special function YANG Main CFD Forum 3 August 4, 2003 10:12
About special purpose FLAIR Constantinos Constantinou Phoenics 1 June 11, 2001 22:45
About special purpose Airpak Constantinos Constantinou FLUENT 0 June 11, 2001 10:00
