March 7, 2014, 14:01 |
oscillating cylinder dynamic mesh
Rep Power: 12 |
Dear Foamers,
I just start to learn how to use openFoam and now I want to use the dynamic mesh to simulate a flow past an oscillating cylinder. However, for the dynamic mesh, I can only let the cylinder go one direction like the following dynamicMeshDict document. /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh solidBodyMotionFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); solidBodyMotionFvMeshCoeffs { cellZone Fluid; solidBodyMotionFunction linearMotion; linearMotionCoeffs { velocity (0 -1 0); } } // ************************************************** *********************** // Could you tell me how to make the cylinder oscillating specifically in the flow? Thank you so much for your help. |
March 24, 2014, 11:39 |
#3 | |
Rep Power: 12 |
If you give more detail about your question, it will be better I think you need add on pointDisplacement in your 0 docunment. However, now I still could not run the case successful. Because it is always diverge. I do not know too much about pimplefoam... |
March 24, 2014, 11:47 |
ok
Many thanks for your reply.
I already finished the case about flow past a circular cylinder (case attached). Now I would like to make cylinder goes up and down. What are the changes I have to add to my case to get what I'm looking? Any idea would be welcomed. |
March 24, 2014, 12:03 |
#5 | ||
Rep Power: 12 |
I think you need to add on a piontDisplacement in your 0 document to define the cylinder's motion Quote:
However, I am not sure could it run successfully, but actually cylinder { type oscillatingDisplacement; amplitude (0.1 0 0); omega 1; value uniform (0 0 0); } is defining your cylinder's motions Hope it help |
March 24, 2014, 12:22 |
ok
Many thanks. I will try that you post.
March 25, 2014, 05:29 |
ok
Dear Scabbard,
just to make sure what's inside dynamicMeshDict file? My dynamicMeshDict file is shown below Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicInkJetFvMesh;//dynamicMotionSolverFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); //solver velocityComponentLaplacian; //velocityComponentLaplacianCoeffs //{ // component x; // diffusivity directional ( 1 200 0 ); //} dynamicInkJetFvMeshCoeffs { amplitude 0.1; //0.5; frequency 1; //2; refPlaneX 0; } // ************************************************************************* // Last edited by wyldckat; April 5, 2014 at 11:30. Reason: merged posts, 1h apart |
March 25, 2014, 07:50 |
Rep Power: 12 |
Dear Maimouna,
Sry my friend, I am still looking for the meaning of the dynamicMeshDict... If I got any idea, I will post on the forums. |
March 25, 2014, 08:31 |
ok
Many thanks. I'm looking forward your post.
If I got any I will post it too. All the best |
March 25, 2014, 10:16 |
ok
Dear Bruno,
I was working in flow past a circular cylinder in OpenFOAM 2.2.2. I just finished my case (attached). Now, I'm looking for how to make that cylinder oscillate (up and down)? What should I changed on my case for free vibration of cylinder in flow. I knew that I have to add pointDisplacement in 0 folder Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.0 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class pointVectorField; object pointDisplacement; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 0 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (1 0 0); } outlet { type fixedValue; value uniform (0 0 0); } top { type empty;//fixedValue; //value uniform (0 0 0); } bottom { type empty;//fixedValue; //value uniform (0 0 0); } walls { type slip; //zeroGradient; } cylinder { type oscillatingDisplacement; amplitude (0.1 0 0); omega 1; value uniform (0 0 0); } } // ************************************************************************* // Also, I need to add dynamicMeshDict in constant folder. What's included? Shall I changed my solver from pimpleFoam to pimpleDyMFoam? Looking forward you help please Last edited by wyldckat; March 28, 2014 at 17:53. Reason: merged posts, as the only detail missing was the attachment |
April 1, 2014, 07:45 |
#11 |
ok
Dear Scabbard,
did you get any idea about how making cylinder moving up and down? If any shearing me your idea please. |
April 2, 2014, 11:27 |
#12 |
ok
Dear OF users,
I need your help please to give me hint of how to make cylinder oscillating in the attached case. I spent for that more than 3 weeks and I didn't get the result till today. So, I'm waiting your help my friends. In that case: - Mesh was generated by Gmsh. - U = 1m/s^2, D= 1m, Re = 100. - Other information in the attached folder. I'm looking forward to get your help please. |
April 5, 2014, 11:59 |
#13 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
I don't have enough time today to look into this, but I think Maimouna is in the right track. First of all, let me make a reference to the list of useful threads Maimouna had posted on and I then moved the posts to this thread, for keeping the topic in a single thread:
Let's see... the "pointDisplacement" is meant to be used by only a certain group of mesh motion solvers... If you look for "displacementMotionSolver" in the source code documentation page - http://foam.sourceforge.net/docs/cpp/ - you'll see that there are a few motion solvers that use the "pointDisplacement" field, as shown in the first attached image. The candidates are:
If we use this command: Code:
find $FOAM_TUTORIALS -name dynamicMeshDict In addition, you can use the moveDynamicMesh solver, which only moves the mesh and does not do any flow simulation. This is useful for figuring out how the mesh is moving along time. Oh, and there was a thread that had a neat example case... where instead of a cylinder, it was a moving wall... actually, here's two:
Beyond this, I'll have to test things myself and that will take quite some time. Best regards, Bruno
April 5, 2014, 14:39 |
#14 |
ok
Dear Bruno,
many thanks for your post. I'm going to try what you post and I will post if any new result. Waiting your trying as well. Best regards |
April 11, 2014, 14:25 |
#15 | |
Rep Power: 12 |
Sorry for the late reply, I am still try to get it oscillating, because I am simulating in turbulence so now still the programme can start run but can not converge always got error. so I am not sure now... Sorry Hope you have already solve the problem. Best wishes |
April 11, 2014, 17:38 |
#16 |
ok
Dear Scabbard,
yes, I solve my oscillating problem in laminar flow for forced vibration but not in natural vibration. I'm still working to get the result to make comparison between both. Once finished, I'm going to post them both. All the best. Maimouna Kind regards |
April 12, 2014, 09:49 |
#17 |
Hello all,
I hope you have a good day. I am trying to simulate the same thing. Dear Maimounda, by natural vibration of the cylinder, you mean the vortex induced vibrations causing cylinder to oscillate? With all the best, Mojtaba
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
April 12, 2014, 12:11 |
#18 |
ok
Dear Mojtaba,
exactly, in the natural vibration don't need to specify a motion for the cylinder. Let the cylinder (within certain constraints) move accordingly to how the forces caused by the fluid act on it. The difference between forced and natural vibrations is essentially the boundary condition on the cylinder in pointDisplacement file in 0 directory. I hope that help. Maimouna |
April 17, 2014, 08:19 |
#19 |
Joachim Herb
Rep Power: 21 |
I think you are looking for "fluid solid interaction" simulations using OpenFOAM. Googling for it, here are some links I found:
http://www.cfd-online.com/Forums/ope...-openfoam.html http://openfoam-extend.sourceforge.n...re_Interaction http://training.uhem.itu.edu.tr/file...50927-file.pdf http://www.personal.psu.edu/rlc138/r...ell_thesis.pdf At them moment, it looks like it is not supported in standard OpenFOAM but in the extended project. |
April 19, 2014, 09:06 |
#20 | |
Rep Power: 12 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 08:03 |
dynamic mesh refinement and rhoCentralFoam | ChrisA | OpenFOAM Running, Solving & CFD | 1 | March 21, 2013 08:00 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
