Setting velocity profile at the inlet using codedFixedValue |
May 11, 2014, 12:26 |
Charles
Rep Power: 12 |
Hi everyone,
I am trying to impose a velocity profile at the inlet of a duct. The velocity profile is dependent on y and z coordinates and the flow is in the x direction. I have attached my 0/U file as well as the error message that I got in a txt file. I am not really experience with c++, so it is likely that the mistake is in my inlet boundary code. I have been able to run the solver that I wrote with uniform velocity just fine. I don't really understand where the problem is exactly. I am running OpenFOAM 2.2.2. Any help would be much appreciated. Regards, Charles |
May 20, 2014, 12:01 |
Joachim Herb
Rep Power: 21 |
I think here is a working example using swakFoam:
http://www.cfd-online.com/Forums/ope...swak4foam.html I would start with this example and then modify it to use your formulation of the profile. |
How to apply velocity profile at inlet | Sam | CFX | 12 | April 1, 2012 06:52 |
Inlet Velocity Profile BC - Floating Point exception during solution initialization | Janshi | STAR-CCM+ | 4 | March 14, 2012 10:21 |
FSI- Pipe- uniform velocity profile inlet | Absy | Main CFD Forum | 0 | April 6, 2010 03:01 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
inlet velocity profile in Polyflow | srinu | FLUENT | 0 | January 16, 2003 20:25 |
