logarithmic profil LES
Old   July 22, 2014, 08:02
Default logarithmic profil LES
hydraulic is on a distinguished road
Dear Foamers,
I would like to simulate the flow over an heterogenous terrain (xyz~1km*0.6km*0.3km) using LES. My inlet velocity should have a logarithmic profil. The atmBoundaryLayerInletVelocity is only available with RANS
After reading the forums discussions, the different provided by OpenFOAM, i found there are 2 ways:
1. Do a separate simulation of a cyclic channel and store every inlet (do you know which boundary condition should be put at the outlet of this simulation?)
2. Use the mapped BC at the inlet.
Do you have some recomendations/experience in 2 methods?
Thank you in advance for your reply,
hydraulic is offline   Reply With Quote
LES Filtering: how are the small and large scales equations solved? atmcfd Main CFD Forum 38 March 14, 2016 14:52
SpalartAllarmasIDDES LES model mmmn036 OpenFOAM Running, Solving & CFD 1 April 23, 2014 20:01
Beginning to work in LES - Suggestions needed atmcfd Main CFD Forum 5 July 20, 2012 22:16
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
