mapFieldsDict expert wanted!
Old   August 25, 2014, 12:57
Default mapFieldsDict expert wanted!
Nick Gardiner
NickG is on a distinguished road
Hi
I have a simple aerofoil case where I want to split the foil into upper and lower so that I can play with the wall roughness on each side.
How do I set up mapFieldsDict to run from a stable solution where the foil is one patch, into one where the foil is now split in two patches?
i.e. What do I put in patchMap or cuttingPatches?
Thanks
Nick
NickG is offline   Reply With Quote
Old   August 26, 2014, 01:53
Bernhard
Bernhard is on a distinguished road
Did you try to run mapFields without the -consistent flag?
And maybe in the mapFieldsDict you need to put
patchMap
    upperFoil foil
    lowerFoil  foil
I don't think you need cuttingPatches, as it look like your domain did not change.
Bernhard is offline   Reply With Quote
Old   August 26, 2014, 06:50
Nick Gardiner
Thanks Bernhard
I'll try that. I didn't use -consistent but had other options flagged. I think I'm ok with mapFields except for the ..Dict part...
Nick
Problem with mapFieldsDict samiam1000 OpenFOAM 2 January 3, 2020 04:58
MAxium residual...confusion with expert parameter KK CFX 3 February 8, 2008 10:47
asking for a few expert parameter for rotarywing charles CFX 4 November 3, 2006 14:15
Expert Parameter for compressible transient ioannis CFX 0 November 2, 2005 19:28
Help on EXPERT Tim Phoenics 5 August 21, 2001 14:15
