Error in meshing a Ship hull using snappyhexmesh
Old   August 27, 2014, 02:59
Default Error in meshing a Ship hull using snappyhexmesh
Sachin
Sachin m is on a distinguished road
Iam working on a customized hull.when i used snappyhexmesh, i got the following error message:
/ubuntu-2.1.0/run/wigleyHull(2008) paraFoam
created temporary 'wigleyHull.OpenFOAM'
~/OpenFOAM/ubuntu-2.1.0/run/wigleyHull(2009) snappyHexMesh -overwrite
| \\ / O peration | Version: 2.1.0 |
| \\/ M anipulation | |
Build : 2.1.0-0bc225064152
Exec : snappyHexMesh -overwrite
Date : Aug 27 2014
Time : 17:31:26
Host : "ubuntu"
PID : 5226
Case : /home/ubuntu/OpenFOAM/ubuntu-2.1.0/run/wigleyHull
nProcs : 1
Create time
Create mesh for time = 0
Read mesh in = 0.07 s
Overall mesh bounding box : (-10750 -5750 -5500) (20250 5750 5539.9)
Relative tolerance : 1e-06
Absolute matching distance : 0.0348587
word::stripInvalid() called for word ��~?�-����ҽ��i?t�D�ȒD+�Z?�ίD��D�cU?��D3k�D
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
~/OpenFOAM/ubuntu-2.1.0/run/wigleyHull(2010)
Can anyone tell me what the problem could be?
I had to scale the geometry using convert to meter and the value was 1000.
The hull was modelled in Free ship and was imported to solidworks and was then converted to stl format, since the stl file generated from the freeship was just a half part of the symmetric body.
Sachin m is offline   Reply With Quote
Old   August 27, 2014, 23:27
Sachin
If anyone has encountered this problem, the reason is that you have a bad geometry file.
The stl files that you import from some of the cad softwares have this problem.
try importing a different geometry file.
Flow around ship hull, multiphase setup!! alibul FLUENT 15 February 21, 2019 02:50
Tetra Meshing over Frigate Ship Model rohitsaini@y7mail.com CFX 11 September 3, 2012 14:26
[snappyHexMesh] Meshing a sphere with snappyHexMesh Cyberholmes OpenFOAM Meshing & Mesh Conversion 2 July 19, 2011 16:46
[snappyHexMesh] Ship hull using snappyHexMesh nuovodna OpenFOAM Meshing & Mesh Conversion 1 June 28, 2011 10:45
[GAMBIT] Meshing complex geometry (Hull) vmeertens ANSYS Meshing & Geometry 26 March 29, 2010 10:24
