Initial conditions and change in reference frame |
November 24, 2014, 09:21 |
Jim
Rep Power: 12 |
Hi All,
I am running a 2D transient case for an object moving in a static tube passing a junction (T-junction effectively). Dynamic meshing has been used to move the object using pimpleDyMFoam. The resultant flow is generated purely by the moving object. I have created an initial condition for this model (some distance before the object reaches the junction), based on a simple pipe with the object placed in it, with an inlet-outlet flow equal to the object velocity. The model is steady state using simpleFoam. My question is: In order to use the steady state model as my initial condition I must change the frame of reference from the object to the tube. Is this as simple as subtracting the inlet velocity from the initial condition velocity field (in the x-direction)? Thanks in advance |
dynamic meshing, frame of reference, initial conditions |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
