Non uniform inlet specification
Old   May 19, 2015, 16:49
Default Non uniform inlet specification
Albert Pressler
AlbertPressler is on a distinguished road
Hi all,
I need to specify an inlet that represents a large rectangular air flow inlet area where a grid of flow velocities and temperatures have been measured in reality. So the resulting modeled inlet boundary would look like a checkerboard, every field representing one measurement.
What would be the easiest way to specify those different inlet BCs without defining all individual inlets in the files?
After looking aroud the forum I guess Groovy BC would be the tool to go for, probably in conjunction with a lookup table that contains the measured data. My problem is, I'm not really familiar with the syntax and I don't know how to define the locations of the inlet fields within the Groovy BC description as well as the data file.
Can someone give me a hint if that would be the right way and how I'd have to define it?
Thanks a lot!
AlbertPressler is offline   Reply With Quote
Old   May 21, 2015, 05:44
Smile
T.D. is on a distinguished road
Hi Albert,
For a checkerboard inlet BC, it will be somehow difficult to handle with groovyBC.
You can directly implement the code in your solver via the following methodology:
// First get the label of your inlet boundary by:
label myinlet = mesh.boundaryMesh().findPatchID("inlet");
// Then get inspired from this thread:
http://www.cfd-online.com/Forums/ope...ion-class.html
Best Regards,
Good Luck !
T.D.
Originally Posted by AlbertPressler View Post
Hi all,
Thanks a lot!
T.D. is offline   Reply With Quote
Old   May 25, 2015, 06:49
Albert Pressler
Thanks a lot T.D. for your answer, but I'm afraid I don't really know what to do with it...
How and where do I specify the inlet conditions for the various patches?
Or would it be easier after all to just set up 64 inlets? Sorry but I'm not much of a coder and not very familiar with chenging solver code...
Old   July 16, 2015, 07:06
OK. You can still learn some coding.
Everybody can (only if he/she wants to)
Regards,
T.D.
dsmcFoam setup hherbol OpenFOAM Pre-Processing 1 November 19, 2021 01:52
Channel flow using InterFOAM DanM OpenFOAM Running, Solving & CFD 49 July 31, 2020 11:43
Is there a bug when running createBaffles in parallel??? zfaraday OpenFOAM Pre-Processing 1 May 12, 2015 13:32
LES supersonic free jet martyn88 OpenFOAM 22 April 17, 2015 06:00
interFoam/kOmegaSST tank filling with printStackError/Mules simpomann OpenFOAM Running, Solving & CFD 3 February 17, 2014 17:06
